wunderlich extreme inner fender
r1200rclassic
Post by r1200rclassic »
anyone install one of these? Anything special I need to know?
http://www.wunderlichamerica.com/motorc ... 60706.html
2012 R12R "Classic" - ESA II, ABS II, ASC, Heated Grips, Computer, Windshield Sport
SF_Hooligan
Re: wunderlich extreme inner fender
Post by SF_Hooligan »
I think you should know that's too much to pay for an inner fender. :lol:
(sorry, couldn't help myself)
If you haven't already, you might want to check out the MudSling from the MachineArt Moto folks. Although it lacks the "striking appearance" of the Wunderlich item.
MTBeemer
Donating Member #: 1043
Post by MTBeemer »
+1 on the MachineArtMoto inner fender. Easy to install, effective and a much better deal.
Kevin Huddy
Intrepid Incompetent
Canyon Creek, MT
Woland
Post by Woland »
MTBeemer wrote:+1 on the MachineArtMoto inner fender. Easy to install, effective and a much better deal.
Indeed, I have an Ilmberger carbon fiber hugger on my R but if I'd buy today it would be a mudsling for sure.
r1200rclassic
alas, I already own it, it's in the garage waiting for me to get home form this trip and install it... I was more curious if there is any torque settings, etc.. that I need to worry about when I install it. Directions seem to just say use "lock tight" but nothing about a torque setting.
Shakey
Donating Member #: 961
Post by Shakey »
The Wunderlich "Hugger" or Inner Fender looks pricey compared to the same unit from Puig.
http://www.motorcycle-exhausts.co.uk/PU ... 12256.html
I first fired a Mudsling to my 2011 bike and whilst this does a great job of keeping the rear shock clean, it does nothing to stop the water and dirt being slung up into the undersea area. So I tried to fit the Puig hugger as well but as one is on the sprung and the there on the unsprung parts of the bike, they rub together so sadly my mudsling came off. I may modify it to try to refit it.
With the Hugger though, the results are pretty much identical to the mudsling and I still have to clean up under the seat after ridning in heavy rain. Please somebody make a better citing undertray for this bike!
In the meantime, Duct tape will have to do :roll:
Martin
curmudgeon
Post by curmudgeon »
You might want to consider the Nippy Norman's hugger. I've had one for several years without issue and it's very reasonably priced. It does a good job of keeping the spray and crud off of the bike.
http://www.nippynormans.com/products/hu ... -r1200r-bk
2008 R1200R Granite Gray
r1200rclassic wrote:alas, I already own it, it's in the garage waiting for me to get home form this trip and install it... I was more curious if there is any torque settings, etc.. that I need to worry about when I install it. Directions seem to just say use "lock tight" but nothing about a torque setting.
It apparently mounts to the paralever lever mounting and to one of the brake caliper mountings..
Brake caliper bolt = 24 Nm
Lever arm bolt/nut = 43 Nm
I'd only use Loctite on the lever arm bolt/nut - or a new nut (it's supposed to be a one-time use.. it's a deforming threads locking nut.) But that's me.. you may want to follow their suggestion.
r1200rclassic
thanks Don, that's the info I was looking for!
