pri ign does not work
Posted: Tue Jul 03, 2012 10:32 pm
I have an electrical mystery.
'04 rockster, 50K miles. Bought new.
Bike was in storage for 18 months while I was out of the country. Was running great when I left. Bike is always stored inside or covered with good cover
This is not a fuel problem.
Everything on the bike works except the primary ign. Here is what I have done so far.
New hall sensors and they will light off the fuel pump every 180 deg.
New stick coils and ign leads.
New plugs and tested with both grounded.
New TPS adjusted correctly.
Tried another ECU from an R bike with dual ign.
swaped the relays around and cleaned contacs
No blown fuze.
Side stand sw checks out
Netural sw checks out
kill sw checks out
Clutch sw checks out.
Ign sw seems ok as everything but the pri ign works
bike will run on secondary ign but poorly. When running the cyln head temps are within 10 deg.
Does not seem to be any power for the stick coils. I have a clymer manual and the wireing diagrams not so good. It shows power to the stick coils supplied via the load control relay? Checked the 4 wires ti the 2 stick coils and detected no short or ground. 145mV on the signal wire while cranking. Don't know if I should be reading 12V on the green wire with ign sw on.
OK sweatmark, I have seen allot of your comments on the R electrical system..what do you think? Any ideas?
pouzzled
mike
No blown fuze.
kill sw checks out
pouzzled
mike
