Fast Blinker
Bluehenrider
Fast Blinker
I just noticed my right turn signal blinks extremely fast. I am assuming a relay somewhere is going bad.
Black 2002 R1150R
Re: Fast Blinker
Maybe the wrong bulbs.
02R1150R,02R1150Rabs,04R1150R
02R1100S,05R1100S(BCR),
(2)-S1000XR
IBA#7147
IBA#7147
ColumbiaBMW
Re: Fast Blinker
My bike has had the same problem for over a year now, and I've started a couple of posts about it. I've taken it to the shop (they couldn't duplicate the issue since it only does it sometimes, so they couldn't do anything), I've replaced the bulbs, and I even bought a new turn signal relay off someone on here, and that didn't do any good either. Good luck figuring it out, and be sure to let me know what it is when it gets fixed.
Bryan
2010 R1200R
2010 R1200R
Bluehenrider
Bluehenrider
Re: Fast Blinker
3463
Re: Fast Blinker
Hi there!
I had same problem but i've solved it.
The bulbs in the bike where 10 watt and the default is 21 watt that was the problem maybe, when the bulbs are too big you can buy smaller bulbs but when you need yellow, you must paint it.
The 21 watt smaller bulb: http://www.ebay.com/itm/AUTOMOTIVE-LIGH ... 4d00e7ba07
I hope it was useful..
ColumbiaBMW
Re: Fast Blinker
The issue will most likely come back again, mine always does that too. It will blink fast, go away a few days, do it again. And I went through everything like checking all the wires, indicator bulbs, even bought a new flasher relay. Nothing ever worked, but then tonight I saw this thread on advrider:Bluehenrider wrote:Fast blinker stopped on it's own. No idea why.
http://advrider.com/forums/showthread.p ... ght=r1150r
So after reading about how the problem came from his pilot light in the head light, I went and checked mine, and sure enough it was completely burnt out. So tomorrow on my way home, I will definitely be stopping for a new bulb, and hope that solves my problem.
Bryan
2010 R1200R
2010 R1200R
