Bike wont start after changing quick disconnects
Posted: Sun Mar 10, 2013 9:12 pm
by RanTheRedCedar
Hi guys,
I'm hoping you can help me out with this. Like many of you I snapped off the male end of a QD while putting the battery back on. I replaced the QDs with the steel ones from beemerboneyard (thanks for all the posts regarding changing these), but when I put it all back together the bike would sputter and try to start but wouldn't catch. Ended up killing the battery trying to start it. Any clue on why this happened?
Other things to note: Bike hasn't been started in about 2 months (winter). The fuel pump was making a progressively higher pitched whine as I tried to start it - meaning I would try to start it, it wouldn't, then as the pump built pressure back up after, it would have a higher pitch than the last time I tried to start it. I've never noticed the pump noise do that before but I've never had to crank it more than 3x.
Is this something where the pump has to get rid of the air in the system and is normal or....?
Really need an answer quick, as I have it in a storage unit and my move out date is next Monday. I can extend for another month, but at $120 a month, I'd rather not.
Thanks!
Re: Bike wont start after changing quick disconnects
Posted: Sun Mar 10, 2013 9:37 pm
by sstein
Check to make sure the throttle cable is seated correctly in the throttle body on the right side. This can get dislodged during engine removal.
Posted: Sun Mar 10, 2013 10:03 pm
by Sunbeemer
The right hand throttle cable not seating after a tank removal is a common problem (it even happened to Charley Borman on the "Long Way Around" tour), but this sounds like the quick disconnects are not mating properly...I'd try disconnecting them and reconnecting them very securely and see if that doesn't fix it.
Posted: Sun Mar 10, 2013 10:26 pm
by RanTheRedCedar
Thanks guys,
I actually checked the throttle cable, and now that I have the tank back off, I'll be able to reconnect the QDs to see if maybe it works this time. Wouldn't it be leaking gas if they are connected but not properly?
Posted: Mon Mar 11, 2013 12:49 am
by kirby
RanTheRedCedar wrote:Thanks guys,
Make sure you have not switched the two fuel lines. One is pressure from the pump and the other return.to the tank. Engine will not run with them switched! Its been done before!
mike
Posted: Mon Mar 11, 2013 8:43 am
by RanTheRedCedar
I saw other peoples comments about ensuring you didn't connect the lines wrong. I changed the QDs one at a time and made sure to have them in a flipped orientation so I can't confuse one with the other - we can check that off the list.
I'll be doing my second attempt tomorrow so I'll keep you updated if I find anything and/or if I get it going.
Posted: Mon Mar 11, 2013 9:20 pm
by Sunbeemer
It's possible they were not plugged fully together, which is necessary to open the check valves inside each half of the quick disconnect to allow fuel to flow. The internal check valves prevent fuel from flowing freely when they are disconnected.
Posted: Wed Mar 13, 2013 9:34 am
by Bobmws
RanTheRedCedar wrote:Hi guys,
Thanks!
The fuel pump high pitched whine is indicative of the fuel filter being clogged. There is a pressure relief in the fuel pump that will emit a high pitched sound when it bypasses.
Posted: Thu Mar 14, 2013 12:34 pm
by RanTheRedCedar
Figured it out with your help!
I had unseated the right side throttle cable. I had checked it after changing the QDs, which is why I didn't think that was the issue initially. It started up this time I and heard the right side wasn't firing. Checked the throttle cable and that was it. I must have unseated it while replacing the tank after the QD change...
Thanks for the tip about the fuel filter too. That was on my list of maintenance this spring so that is some good timing. Definitely do not want to strain that pump or get unecessary gas impurities in the system!
Posted: Thu Mar 14, 2013 3:55 pm
by omg1010
Classic mistake which has probably happened to all of us at some stage .... Even me in the very beginning ... :lol:
Brgds
Oliver
Posted: Sat Mar 16, 2013 10:52 pm
by RanTheRedCedar
Yep, I am definitely outside of my realm of knowledge. I have only done the basic fluid changes & tank removal so far, but am looking forward to trying the more complex stuff!
MfG,
RTRC
