Has anyone ever tried one of these?
Posted: Fri Apr 19, 2013 11:03 am
by DanH
http://www.ebay.com/itm/Throttle-Cruise ... 35ba2ff960
Like the idea that it doesn't lock the throttle, just gives you an easier way to hold it when you need to rest your hand.
Re: Has anyone ever tried one of these?
Posted: Fri Apr 19, 2013 11:58 am
by RedRyder
had a couple different ones over the years. one was wider than the other. they are just ok. they get in the way of my ability to use the throttle effectively in curves and when you come off a country road/highway into residential areas they are a pain. if you are going to "slab it" for a few hours then they work fine. definitely cheaper than throttlemeister and the other bar end locks. heck, if you want i will send you one for free.
these work great, but I have only used it on my VFR: called GoCruise (
http://www.thecycleguys.com/go-cruise-t ... -assist-1/)
Posted: Fri Apr 19, 2013 12:37 pm
by Ol' Jeffers
I use a similar thing and find it very useful on a long distance ride.
http://www.sportsbikeshop.co.uk/motorcy ... rod/101220
Posted: Fri Apr 19, 2013 8:42 pm
by mnnden
RedRyder wrote:had a couple different ones over the years. one was wider than the other. they are just ok. they get in the way of my ability to use the throttle effectively in curves and when you come off a country road/highway into residential areas they are a pain. if you are going to "slab it" for a few hours then they work fine. definitely cheaper than throttlemeister and the other bar end locks. heck, if you want i will send you one for free.
Yes, That is about how I would sum it up, better than nothing, but just barley! the GoCruise (type) work a lot better, but even with those a little "Kentucky Windage" needs to be applied, ( I use rubber bands) I have them on a couple of bikes & prefer them to the thumb type JMOP
Posted: Sat Apr 20, 2013 6:48 am
by Bobmws
I use a throttle rocker (similar to what you show) on my K bike due to the extra spring tension on the throttle bodies. It takes a bit of adjusting to both the device and yourself to get it in the correct position so it doesn't interfere in local road riding. The K has a real cruise control for the highway!
It's cheap enough, give it a try.
On the 'R' I have a Kaoko which I find to be very effective and easy to use.
