Pictures of underseat exhaust
Posted: Fri Sep 02, 2005 8:33 am
Hi guys,
I can't believe another summer is passing by without putting many miles on the bike. My job (NYPD Detective), twin boys both 16, Corvette cruises, yada yada yada...
Anyway, I have had several email requests for some detailed pictures of the exhaust on my bike. This morning before work I took some and I hope they help those that asked for them. I can post different angles if needed.
The cans don't get hot at all. Minimum popping, just usual downhill off throttle that "they all do" : )
The bike is a bit higher because of the shorter Paralever arm. This helps with clearance. I have ridden with two up and there has been no real clearance problems.
It sounds good, much much better than stock.
Hope it helps,
Bobby A
Hope it helps,
Bobby A
