R1150R will not fire the injectors.
Posted: Wed Sep 24, 2014 8:31 am
by Yangins
History
Was running. Cultch spline went o on the clutch. Replace clutch and put everything together. Bike will not start.
Fuel pump is priming.
Checked Spark it is goo on both cylinders.
Check all the Fuses. non are blown
Have fuel all the to the injectors.
Check the kick stand sensor it is good also. Fuel is prime when in neutral and first gear with clutch held in.
I double check the ground and all the connection. They seems to be connected.
Unplug injector from throttle body. leave fuel line and connector attached. Fuel injector is not spraying any fuel on either side when cranking the engine.
any help to diagnose the issue would be great?
Re: R1150R will not fire the injectors.
Posted: Thu Sep 25, 2014 10:13 pm
by sstein
Did you reconnect the two fuel lines correctly? One takes fuel out to the fuel injectors, the other is a return line to the tank. Or is a line pinched or kinked? Is the starter cranking? How do you see fuel getting to the injectors?
Just some thoughts.
Good luck.
Posted: Wed Oct 08, 2014 10:19 am
by Yangins
Fixed it. injector were firing. the fuel hose came off the fuse pump.
