Where did the oil go?
My oil (idiot) light is on. I see there is no oil in the sight glass. I put more oil in, and i eventually get a full oil change.
The next day, the oil is not in the sight glass again, and the oil light is on again. Mechanic put in a new switch - i believe for
sending the oil - and it worked that day. I rode around a little. Next time i go to ride, i have both again - oil light is on, and
i can't see any oil in the sight glass. There are no leaks. I don't see any oil anywhere, and I don't believe it's burning any. I had
only ridden it a little. Where could the oil be going? Has anyone had this issue and no what it is? I shouldn't be running it,
but it runs fine. Thanks.
2002 R1150R black
Re: Where did the oil go?
If it's cold out, then the oil is probably stuck up in the oil coils.
Buckster '03R
#543
#543
The window gives false readings. I'd drain the oil out change the filter and put in the 3.9 qts. to know where I'm at (Do an oil change). Then figure out why the light is coming on, checking all the wiring for a pinched grounded out wire. Something has to be wrong with the circuit including the sending unit being suspect. Maybe even a corroded fuse?
02R1150R,02R1150Rabs,04R1150R
02R1100S,05R1100S(BCR),
(2)-S1000XR
IBA#7147
IBA#7147
+ 1 on the sight glass misleading sometimes. Warm bike on the centerstand is the best way to check it,
My guess would be a faulty oil pressure switch.
Buckeye Beemer
Been there too!georgek wrote:the answer is i'm an idiot. the oil is there.
Buckeye Beemer
86 K100RS
93 K1100RS
04 R1150R
BMW MOA 123254
93 K1100RS
04 R1150R
BMW MOA 123254
Check the oil upon arrival (hot oil), 5 mins or less on sidestand, then centerstand looking for the oil to be >= 1/2 and < full in the sight glass. Checking before departure (cold oil), tends to give false readings. Overfilling contributes to oil usage.
P Jensen
14 R1200R
Montego Blue
NW VT USA
14 R1200R
Montego Blue
NW VT USA
I tend to check the oil after AT LEAST a 20 minute ride.
Running the bike for more than a couple of minutes on the stand isn't the best idea as things can get overheated quite easily on an air-cooled engine, and you need to ensure the oil is properly up to temperature.
Please explain why? If the oil level is OK hot, why should it subsequently change when it cools down?P_Jensen wrote:Check the oil upon arrival (hot oil), 5 mins or less on sidestand, then centerstand looking for the oil to be >= 1/2 and < full in the sight glass. Checking before departure (cold oil), tends to give false readings. Overfilling contributes to oil usage.
I do understand a first time cold reading after an oil change will not be correct because the oil coolers may not have filled up or drained down.
I have read this topic so many times my head hurts.
I'd quit thinking about this. My "02 is my third oil head, lots of miles. I fill it properly, keep an eye on the overall condition of the engine, change oil at 3K. Generally I find that if I ride long enough to get the engine up to temperature and burn off condensation (at least 25 miles), put the bike on it's center stand for a while and then take a look at the sight glass it will read properly.
Into the engine today. Warmed the bike up with a 20 mile run at 10°C ambient in the rain. Wearing rubber gloves I controlled the oil flow into my tray.
I'm sure I put enough oil back in (3.5 l or so at least) but I guess some is now lurking in the oil coolers with the thermostat closed in the cool weather. Done this job often enough but still is a novelty.
Just need some warm weather but in the UK you never know when.
If the engine is not up to operating temp the oil cooler thermostats will trap oil in the coolers and the lines. Its enough oil to cause the oil in the sight glass to disappear.
So if you do an oil change (engine hot so as to drain all the cooler oil) and put in the required amount in and run the engine to check for leaks the sight glass will give a false reading. Just put in the required amount and don't worry about it and check it on the center stand after you have a good ride and the engine is still hot to get a correct reading.
These engines do NOT respond to over fill and it WILL cause problems if you do overfill.
mike
mike
