Odd Elecrical fault
Odd Elecrical fault
Anyone seen this?
Pull the bike out of the garage one morning and the electricals are dead, until about 30 seconds later, after a few kicks of the sidestand and waggles of the steering.
Ah-ha you all think..... wires near the headstock. Obvious.
BUT - the problem does NOT reoccur once the electrics have come back on! No amount of steering head waggling or kick-stand flicking will cause the cutout to re-occur.
Even stopping for fuel and switching off, then back on again does NOT re-show the failure - everything works first time.
Until the bike is cold again.
So - a wire that only needs to connect once on startup and then is irrelevant until the bike is cold again?
Re: Odd Elecrical fault
Description of "electricals are dead" would help troubleshooting, but I will jump to an unwarranted conclusion: possible problem with the Load Relief relay (K9120).riceburner wrote: Pull the bike out of the garage one morning and the electricals are dead, until about 30 seconds later, after a few kicks of the sidestand and waggles of the steering.
Guess No.2 would be power wiring problem in the harness bundle under battery tray, or grounds.
http://www.advrider.com/forums/showthread.php?t=636907
Long topic thread, but documents a specific R1150** wiring susceptibility and dead electrics issue.
'Electrical are dead' = no power to anything - no starter, no instrument lights, no response to any inputs.
... And consider the ignition key switch.riceburner wrote:'Electrical are dead' = no power to anything - no starter, no instrument lights, no response to any inputs.
sweatmark wrote:... And consider the ignition key switch.riceburner wrote:'Electrical are dead' = no power to anything - no starter, no instrument lights, no response to any inputs.
Agreed - but curious as how that would be affected by steering head movment. The wiring to the switch yes, but the switch itself?
I'll take a good look at it all the same*
* when I get a chance....
Your climate is wet!!! I would clean all the contacts on the relays/fuzes, and any connectors that are under the front that you can pull apart and clean (with the tank off) including the big one to the ECU.
mike
mike
Yes, the switch itself. Like Kirby says, you (and I) live in soggy climate, so there's a chance that the key switch innards have been contaminated.riceburner wrote:Agreed - but curious as how that would be affected by steering head movment. The wiring to the switch yes, but the switch itself?sweatmark wrote:... And consider the ignition key switch.riceburner wrote:'Electrical are dead' = no power to anything - no starter, no instrument lights, no response to any inputs.
1. When bike is cold (per your original post), turn key "ON".
2. Instrument lights and brake light (non-ABS R1150**) should be operable, via power through key switch and Fuse 1.
3. If instruments and brake circuits illuminate, but other components remain powerless (like I feel sometimes), then my guess is the load relief relay.
4. If instrument & brake lights & all else dead, then key switch.
5. Else there's a primary power wire that's sketchy: sizzle, smoke, fire.
Found the issue (eventually)
Also rather annoyingly found the horn wires had gone right at the connector:
I discovered that the ignition switch itself is a replacable part, so ordered one from Motorworks. Called them this morning about the horn connector and they're adding a cutoff from a 2nd hand loom to the order. I HIGHLY recommend them!
Glad you're getting it sorted!
Thanks for tip on Motorworks. In USA, Beemer Boneyard is first option but used parts availability is sometimes limited.
My luck with eBay used parts has been crap - money wasted on stuff in shoddy, unusable condition.
sweatmark wrote:Glad you're getting it sorted!
Should be turning up today.
(that's ordered Monday evening online, and the order amended over the phone Tuesday morning to add the 2nd hand horn connection ).
