I had a loaner F650GS in SCREAMING Yellow to putter around on.
Not sure what year it was, but it had 2400 miles on it when it was
my turn to take it for a spin. It's 20 miles home, then another 20
back, and I did my usual backroad route, so I got a decent feel for
the bike. Here's my 2 bits:
- No choke I could find. Just thumb the starter and go. 55 degrees,
or 38 degrees, it didn't care.
- Engine power was adequate, but not confidence-inspiring, particularly
taking off from a standstill in 1st gear.
- Super light shifter, except going down into 1st at a stop, where you
are met with a resounding CLUNK! and the bike jumps like someone
just spanked its tender backside.
- Speaking of light!! The bike is obviously a lot lighter than the RR.
You just think about turning, and it turns.
- Single front disc brake worked surprisingly well, probably due
once again, to the machine's light weight. The bike had ABS, but
I didn't play with it - it's just not in my nature. I know, I'm
probably the only one here that would say that.
- The stupid little wind deflector on top of the fairing puts the dirty
air right on your helmet - wind noise was so much louder than the
RR that I wished I had brought my earplugs (which I normally
save for the rare highway stint). If I owned this bike, I would pull
that sorry excuse for a windshield off in a heartbeat.
- Heated grips only worked on one dot. Two dots seemed to make
no difference, and it was 38 degrees (and snowing!) the morning
I went to ride back to get BlueBeak. Doesn't seem right for a bike
with only 2400 miles.
- My dad makes furniture, and I worked in the shop for many years.
The F650's engine makes exactly the same sounds as the industrial
sewing machines that he has in the shop.
- Seating position was OK, but the seat was absolutely hard as a rock,
and at every stop, I would slide forward into the tank. (Ouch!)
This bike had a definite Japanese feel to it. It's a lot like the
Kawasaki KLR650. But I suppose that's the target audience.
Not a bad bike, just not my cup of tea.
