Sargent seat question
I've read a lot of good things here about the Sargent seat and have decided to try one. Since I don't carry a passenger very often, I was planning to buy the front only. However, when I called Sargent they said the front only will not fit with the stock rear seat; it's designed for use with the rear cover?? I know I've seen some pictures here with the Sargent and the stock rear seat. Can anyone shed some light on this?
Thanks,
Dwayne
Thanks,
Dwayne
'04 R1150R Black
Sounds strange to me...they modified my front seat only, on two different bikes. Did you inquire about any specific model seat? Or just having foam replaced/reshaped?
Momo on this board is selling his Sargent for a fair price...
http://www.r1150r.org/board/viewtopic.p ... highlight=
#429 (in for life)
'06 Silver R1200RT
'06 Silver R1200RT
peterbulgar
Re: Sargent seat question
That seems strange, but I guess that Sargent would know. Could they have meant that the cover wouldn't MATCH (as opposed to fit) the rear portion?
I have the Sargent passenger seat and am using the stock BMW tall rider's seat - they fit together just fine. (I got the Sargent passenger seat at a BMW Rally after listening to my son complain for three days about the BMW "comfort" seat.) The Sargent cover material is slightly different than the BMW material, but you really have to look closely to see the difference.
peter '73 R75/5, '04 R1150RA
Sargent Seat
I have the Sargent front seat and stock rear on my Rockster and they fit together fine. The Carbon FX is also a close match with the look and feel of the stock material used.
The Sargent seat is a great upgrade over the original for long range comfort.
How Sargent explained it to me was that the rear stock seat will fit if you "jam" it against their front seat. I guess the contour of their seat goes back further than the BMW front seat. It might be fine but I just wanted get some opinions before I buy one. Unfortunately, I can't find a dealer around here who carries Sargent so I have to order it.
Dwayne
Dwayne
'04 R1150R Black
wardieone
seat opinions
Has anyone had theopportunity to compare different seats for comfort and looks. The big three; Corbin, Mayer and Sargent all make good seats I wonder which is the most comfortable over long distances? Any fact based opinions. Wardieone
Fossil Fred
Corbin or Sargent
I've done tens of thousands of miles on both Corbin and Sargent. My personal preference is for the Corbin, although I currently have a Sargent. My wife (pillion) also prefers the Corbin. Both are excellent seats, and very comfortable for a long time. They both start off very firm, but the Corbin seems to mould a little better to our butts, and is just that smidgeon more comfortable.
Either would be a good seat.
Cheers
Fossil
Cheers
Fossil
Seat won't latch
I just got my Sargent seat from RL Motercycles and I can't get the rear seat to latch. It will not latch even with the front seat removed. Has anyone else had this problem?
I figure I will either have to lower the latch on the seat or raise the catch on the bike and if anyone has done either I would like to know how it was done.
In any case, the seat looks good. I was happy with the prompt delivery and price ($530). I got the grip tex because they say it is cooler and in Sacramento I ride in the heat a lot. I hope it is not too bad to clean or to wipe dry in the morning dew. Anybody have experience with this material?
Hey Artattack,
I purchased a front and back 2nd hand last summer and had the same problem with latching the rear. Essentially, the little bracket that is fastened to the bottom of the seat does not extend far enough away from the seat.
The fix I came up with was simply to remove the bracket and install a washer on each screw between the seat and the first rubber bumper.
This got me enough clearance and I've had no furuther problems.
Here's a pic:
Now your passenger just needs a nice BACKREST for that cushy seat!
Here's a pic:
"Never ascribe to malice that which is adequately explained by incompetence" - Napoleon Bonaparte
