Hi peoples
Is it poss to adjust the low fuel light as mine comes on when there are 6 litres/146 mile left and I DON'T ride hard.
There must be a ' thingy' I acn adjust.
renagade
some times my fuel light comes on with half a tank full on board? i found that if the bike is on the side stand the light will light up until the censor in the tank adjusts its self when level (by the way nice to meet to meet nice)
"DO the miles get the smiles" ? so many roads so little time. (silver is the fastest ok)
soldat whats an odometer or do you mean the trip button . just remember that some not all yorkshiremen are renowned for being care full with money I,E AS TIGHT AS A DUCKS ARSE/ BUTT UNDER WATER
REDSTAN wrote: soldat whats an odometer or do you mean the trip button . just remember that some not all yorkshiremen are renowned for being care full with money I,E AS TIGHT AS A DUCKS ARSE/ BUTT UNDER WATER
Hi Stan
Hand is getting better all the time thanks! Healing nicely.
I once got told that a Yorkshireman is just a Scotsman with every last ounce of generosity squeezed out of him!
"You can allus tell a Yorkshireman, but you can't tell 'im much!
It is alot of work, to make that little yellow light come 10-15 miles later, but it can be done. Remove the tank, then pull the fuel pump assembly out, and you will see a small white cylinder next to the pump. There are three or so indents that the low light warning sending unit can click into, put it into the setting that sits it the highest in the tank. Yours might have fell off like mine and is hanging loose, that is why it lights up when there is lots of fuel left. By the way the fuel pump assembly snakes out of the tank like one of those twisted metal puzzles, take your time.
Here's what he's talking about. The fuel pump assembly is placed on the naked bike in nearly it's normal position and orientation. It also shows the relocated canister and how I bent my battery terminals to fit the WestCo battery as mentioned in another current posts.
