Broken luggage
Posted: Fri Feb 09, 2007 4:14 pm
by jred
Last night I was clipping my luggage onto the bike in a pitch black garage. I didn't realize that I had the bags locked and I accidentally broke off the red latch that locks the bags shut. It shuts and latches to the bike but there's no way to lock it. Am I out of luck or can this be fixed?
Re: Broken luggage
Posted: Fri Feb 09, 2007 4:34 pm
by Sparky
jred wrote:Last night I was clipping my luggage onto the bike in a pitch black garage. I didn't realize that I had the bags locked and I accidentally broke off the red latch that locks the bags shut. It shuts and latches to the bike but there's no way to lock it. Am I out of luck or can this be fixed?
There was an article about a year ago in BMW ON on how to fix this exact problem. If you PM me your email, I can send a copy to you either in .jpg format or as a PDF file.
Posted: Sun Feb 11, 2007 2:41 pm
by Sparky
I've emailed the article to two people who PMed me, but my account is acting a bit funky so I don't know if my PM replies went through....
Posted: Thu Feb 15, 2007 4:00 pm
by jred
I got it. Thanks.
I actually have a new problem. The same case (right side) doesn't clip properly into place. It's just barely touching the rear wheel. After examination, I found that one of the bolts that attaches the grab handle was missing and I thought that this might be causing the bag to tilt too far down. However, after replacing the bolt, the case is still touching the wheel. Has anyone ever had this problem? Is something bent out of place? It certainly doesn't look like it.
Posted: Thu Feb 15, 2007 4:37 pm
by MIXR
It's impossible. The case cannot touch the rear wheel if the pillion foot is correctly located between the two plastic tabs on the case.
If it is, only one of two things can be wrong. The rear wheel has come adrift and is mis-aligned, or the bike's frame is seriously bent.
Check the foot and make sure it is correctly located between the tabs on the case. There is a bit of a technique to puting the cass on that usually involves locating the front hook first, the foot and tabs second, then the rear hook, making sure you push the hooks fully down so that the locking mechanism can engage without too much force.
Most lost cases are due to the lower foot not being engaged, allowing the case to swing and pop the top hooks.
Posted: Fri Feb 23, 2007 5:47 pm
by jred
Turned out that the rear sub-frame is bent. I managed to find one for 150 so that's a relief. It would have been 1000 for a new one of 500 to rebend the old one.
Posted: Sun Mar 04, 2007 7:36 am
by Boxerjonny
Sparky
I have just made a similar mistake and snapped off the red tab! Could you please email me the pdf aswell. :oops:
Kindest regards
[email protected]
Posted: Tue Mar 06, 2007 2:23 pm
by Boxerjonny
Guy's
Thanks for the info about how to change the locking tab,
I will order a repair kit from MotorWorks.co.uk £26.00
Regards
Posted: Tue Mar 06, 2007 2:27 pm
by Boxer
You guys need to stop doing things in the dark. :P
Posted: Wed Mar 07, 2007 4:20 pm
by jred
If my landlord ever changed lightbulbs in parking garage, I would be happy to stop doing things in the dark.
Does anyone have any thoughts on patching a small hole in the case? I was thinking that plumber's epoxy might be effective.
Posted: Sun Mar 11, 2007 1:55 am
by Airman
I thought when I saw this thread you guys would tell me how to fix the latch on my broken case. Snapped the hook right off. I removed the latch, but can't find a used one to replace it with. Dang! A new latch is about $75 or so from the dealer.
