def38 is right on with the description of the sync procedure. I would like to expand a bit as to the reason for some of the steps.
Removal and cleaning of the brass idle screws - These screws are fitted with an o-ring, however dirt and debris accumulate above the o-ring and along with the dry-out of the o-ring will make the screws hard to turn (albeit they don't need a lot of turning to adjust).
However more important is that the bottom of the screw is tapered, to regulate the amount of air that bypases the throttle valve (and as such the rpm of the engine). When removing the screw for the first time you will be amazed at the amount of dirt/shadow that has accumulated in the tapered area. I use WD-40 and a rag to clean the screws and a Q-Tip with WD-40 to clean the hole.
Do not use sand paper, scotch-brite or anything that could damage the taper.
Sync of the throttle bodies
The reason for cracking the throttle to 2500 to 4000 rpm is to get the throttle valve to move from the rest position. There is a minute amount of air flowing by the TV in the rest position, but not enough to indicate if both TV's are opening at the same time and the same amount. That is why by cracking the throttle open to, say 3000 rpm, so it alows a large flow to get past the TV with no influence from the idle screw.
The sync of the TB is by far more importatnt to the operation of the bike than the balance of the idle speed. The idle speed will make the bike run rough or kill at idle, the TB's, when out of balance will make the bike run like "caca" since one cylinder will be pulling more air than the other and therefore working harder (remember that the amount of fuel injected will be the same for both cylinders). It doesn't make for a pleasant ride.
Two additional comments on this topic:
The adjustment required to bring the TB's in sync is very small and can be easily disturbed by the tightening of the lock nut. So A) if you have to turn the adjustment screw more than 1/4 turn something is wrong. B) Be extremely carefull that you don't overtighten the locking nut because the threads will strip easily.....and the following will apply:
Cost of cable - What is a few bucs for a BMW owner
Replacing the cable - Major dissasembly with a bit of cusin' and libation of your choice to placate the nerves.
What you learned not to do the next time - Priceless......
On a new bike, typically once the cables strech the owner will find that there is hardly any change in the TB sync and the same goes for the iddle speed, although it has nothing to do with cable strech. We just run a quick check on all of our group bikes (5) at the begining of the season.....
Ahhh....I love this site
