Adventure gas tank on an R1150R?
2 things you can do without altering the tank.
1) switch to Higher octane fuel (I find I get better milage, if not any more speed)
2) Modify the fuel cap tunnel so you can fill the tank fully. (I get around 10-15 miles more to reserve this way).
If you don't have ABS you can also have the tank modified so that it dips into the hole where the ABS would sit - that will give you (at a guess) 3 more litres capacity. (I'm tempted...)
Of course you can also ride in a smoother/more gentle manner - with the first two mods above, and gentle riding (it's winter and it's COLD!) I'm getting around 160+ miles to reserve, which will probably give me about 55 extra miles of reserve if I chose to use it.
DJ Downunder wrote:Good piont...I think if I had a bigger tank fitted I would also have to have a catheter fitted... :D
I may get one anyway. :oops: :lol:
irishbiker
Post by irishbiker »
So when the low fuel light goes on how many miles do i have left before i absolutley have to fill up? About 100 miles gets me to the light.
Warren
Elk grove CA
02 R1150R black
REDSTAN
Post by REDSTAN »
OU812 wrote:
DJ Downunder wrote::D :shock: :D :shock: :D
DJ, where do you find this stuff? :lol: :lol: :lol: :lol: :lol:
DJ it looks like a good long distance tool (BUT WHERE DOSE THE TENT FIT????? :roll:
"DO the miles get the smiles" ? so many roads so little time. (silver is the fastest ok)
Buckster
Donating Member #: 543
Post by Buckster »
Warren,
You might want to look at getting some service done. You should be getting at least 140-160 until your light comes on.
Usually I would say you might get 40 miles after the light comes on.
Maybe more, but I wouldn't chance it. :smt009
Buckster '03R
#543
TicTac50
Donating Member #: 586
Post by TicTac50 »
riceburner wrote:2 things you can do without altering the tank.
1) switch to Higher octane fuel (I find I get better millage, if not any more speed)
I did the search, but can not find the instructions how to modify the fuel cap tunnel. Remember something about drilling the hole, but where??? :oops: :oops:
If anybody got a pic or instructions, I would appreciate the help.
Thanks.
Lifetime Member #586
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
Donating Member #: 312
Post by boxermania »
To those with early yellow lights - Your light adjustment is bad or your bike needs tuning ....really.
Any oilhead with a reasonable state of tune and ridden in any fashion other than WOT will go 160 to 180 miles before the yellow light comes on.
I checked many times over with any type of gas and in various parts of the US and could set my watch on the yellow light coming on between 172 to 176 miles. The fill was always 4.1 to 4.2 gallons, meaning you had one gallon left. Taking inventory and accountng for the split in the tank that leaves a long 20 miles to look for gas before you start to worry.
I'm against adding external fuel tanks, they are dangerous, even if it is a fuel cell, because at ~8 lbs/gallon it will affect significantly the balance of the bike.....obviously much more so if you carry luggage. In addition, anyone that rides needs to strech every couple of hours, if you want to enjoy good circulation in your old age.
So if you ride at 80 - 90 mph, you need to stop about every two hours.....you see everything works....and the number one too.....just my 2 cents. 8)
boxermania wrote:To those with early yellow lights - Your light adjustment is bad or your bike needs tuning ....really.
what kind of revs were you riding at? I regularly (as in daily) am going over 80 in winter, and over 100mph in summer, just on my commute. I also tend to ride reasonably rapidly (not flat out, but rapidly) on weekends and touring. Fuel usage is going to depend a LOT on how the bike is used.
Although I agree that 100 miles to reserve is scary!
(and my light is deffo green. ;) )
Most of my driving was done at 3500 rpm to 4500 rpm, which in my old bike equated to an indicated 70 mph to 90 mph.....ocassionally over that when passing on the slab.
When my buddy (R1200C) and I traveled from Baton Rouge to New Orleans, 63 miles away to catch some Thai food, we used to do it around 42 minutes for an average of 90 mph.
No, I'm not proud of our accomplishments, we made up for it on the way back, with a full tummy, at a law abiding 70 mph..... :lol: :lol:
Croc
Post by Croc »
Where can I get a can like that??
Croc
Wind in your hair......
Silver '03 ABS (Twin Spark)
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
Before I bought my RR, I tried out a GS-ADV and, while thinking the extra range was nice, didn't like the top-heaviness the tank imparted to the bike, which was little taller than my RR too, so that would also affect the handling. All in all, I wouldn't want that thing on my bike, I like the nimbleness of a low CG!
ADIOS!
boxermania wrote:riceburner
hmm - I'm now thinking that the top gear on my bike must be shorter than I thought - I know I'm revving higher than that at 80-90.
