OH!NO! Someone has stolen my lovely black steed...And left only the gas tank to taunt me.
I went back inside to call the BMW police and downstairs in the "Farting" room I found my baby all stripped down and waiting on a massage of sorts.
I managed to finish getting her stripped down for some much needed maintenance and replacement parts. After a most casual pace and making a trip to the hardware store for a 15mm socket I was able to extricate the old 70K mile front shock from its 5 year position and replace with a comparatively "new" front shock. I actually have two "new" front shocks and the one I chose to install first is a used Rockster shock I bought several months ago with 10K miles on it. Its only about 1/2" shorter than the original so I'll most likely feel a slightly different riding position when I get back on the road. The other front shock I have was donated to me by a very kind individual on this board and I will swap out the shorter Rockster shock when I get 20K more miles on it.
Tomorrow brings another day, and I turn my attention to the rear end. My plan is to install a "new" rear shock, but before I do I will take off the clutch slave cylinder and clean it out good. If I see it needs a new one, I'll have to wait until Monday to go buy one.
Brakes, bleeding and/or rebuilding, with new pads, are also on the agenda as is a new fuel filter since I have that blasted tank off.
If I still have time, and chutzpah left, once I get that far I want to take off the final drive and just take it in for a new main bearing replacement as well as pivot bearings.
Rob, if you read this, give me a call. I wouldn't mind letting you do that bearing change out for your customary fee. I know it will be done in a most excellent fashion.
