Plug Cables
Eddiem
Plug Cables
Post by Eddiem »
Aloha
I just got quoted $72.00 per cable at the dealer in Hawaii....What a rip off does anyone can tell me a place where I can order these for a reasonable price??? I hate the Hawaii Dealer they really are a ripoff!
Aloha!
EM
PS: Just checked a couple of the sites Maxe's and Others and the price seems correct, why are these cables so expensive??? It is just a primary cable made out of silicone isn't it??
Does anyone know of any aftermarket Wires??
R-1150 RS (ABS)
Starting to Like Power Assisted Brakes!
Honda XR 650 (Gone)
Post by CycleRob »
The price does sound outrageously steep for 2 wires. To get a replacement you need to be sure they are carbon impregnated fiber wires and not solid wires. With electronic ignition, it's almost always carbon wires, but it can be solid wires with the required resistance placed inside the plastic plug terminal.
Seems like, for about $20 you could buy 2 long lengths of the very best premium quality, high performance, automotive wire made.
R4R&R
Donating Member #: 293
Post by R4R&R »
I think the cable you refer to is actually the coil. Check Beemerboneyard.com - they may have a used one.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
Eddiem
Plug Cables
Post by Eddiem »
R4R&R
Yes the cables I'm refering to are the Coil to the Spark Plug Cables, these cables are plain spark plug cables and should not be actually $76.00 a piece......That is really a rip off....I can understand the Spark Plugs from NGK being $10.00 each but come on $76.00 for a plug wire is way too much!
There has to be someone that makes aftermarket coil to plug wires for these bikes, but I can't find anyone, I will not pay that kind of money for the wires no way Jose!
EM
R-1150 RS (ABS)
Honda XR 650 (Gone)
Post by CycleRob »
I did mention it but it wasn't clear. You can buy carbon sparkplug wire by the foot . . . . . + you can get the crimp terminal ends if needed. Prolly not. The female terminal on the coil usually has a sharp threaded pin in the center that you just screw the wire on to until it bottoms out. Same with the other end at the plug cap.
twindave
Donating Member #: 724
Re: Plug Cables
Post by twindave »
Beemerboneyard.com now sells NEW after market plug wires 58 bucks a pair, plus shipping. I might try a pair since I've had several issues with OEM wires leaking...maybe just a bad batch...who knows. Anyone else have similar problems?
Know it, Love it, Ride it
R601968
Re: Plug Cables
Post by R601968 »
Motorade electric has the cables as a pair as well at $58.00 for the pair. He is very highly regarded, more for air head electrical, if he sells them they will be correct
Donating Member #: 312
Re: Plug Cables
Post by boxermania »
MSD sells what you are looking for, if you are carefull, one can use the parts from the old cables.
http://www.kochwerkz.com/servlet/Detail?no=329179
I'm sure you can check with one of the speed shops in the big Island....... 8)
digga
Donating Member #: 600
Re: Plug Cables
Post by digga »
I just looked att these in the UK...
motorworks.co.uk £36.47 thats about $73 USD according to xe.com !!
i would need to be sure that they were VERY shot, and 100% sure that these were the culprits.. Oh.. and of course thats 2 required.... :badgrin:
