Senior moment
Greybeard
Senior moment
Post by Greybeard »
Don't snicker. You'll get 'em soon enough.
Lit off my '04 the other day and while idling noticed the turn signal indicator lamps on the dash were glowing.
I can't remember if they did that before! :oops: :-k
Turn signals flash fine. (I've got a signal minder on there too.)
Is this normal?
MikeCam
Centurion Moderator!
Donating Member #: 100
Re: Senior moment
Post by MikeCam »
SignalMinder set for Running Lights option causes those dash bulbs to burn all the time.
I think. If I remember correctly. Maybe.
Greybeard
Re: Senior moment
Post by Greybeard »
Hmmm...I know I never set that up.
Now I've gotta' find the manual!
Boxer
Donating Member #: 2
Re: Senior moment
Post by Boxer »
Cam is correct. Hold the turn cancellation button down while pressing the flasher button to cycle through the 3 settings: Bright, Low, Off
It comes from the factory preset for the middle setting I believe.
Buckster
Donating Member #: 543
Re: Senior moment
Post by Buckster »
Mine stay lit all the time.
Don't feel bad, I looked down the other night and saw the red emergency light illuminated on the left side and don't remember that being lit! #-o
Buckster '03R
#543
Greybeard
Re: Senior moment
Post by Greybeard »
Well....I'll be...that did it.
I'd better write that down somewhere!
Yeah...right.
Thank you!
