fallingpines wrote:So now that 'it's alive', how do you like the HID light? I sure would love to have some more light, mind if I ask where did you get it and how much?
As daft as it sounds ... i haven't actually rode in the dark with the HID yet ( summer,light nights etc
But in a darkened garage(!) ........its daylight
the 'bulb' burns at 6000k which is about the same as daylight.
It was an easy(ish) set up and foolproof really.
the bits only fit one way, the problem is location
The cables are a set length and i don't think i'm up to altering wiring etc when one of the boxes says ' do not dis-assemble 23000v'
The kit came from
www.hid50.com and is the H4 kit.
I paid less than the prices on the site, as i bought through another BM site where 1 of the members is a 'rep'
Anyhow....
This is what i basically did.
Tank off, lay out kit and spot places for the ballast, relay and transformer thing.
Headlamp lens and rim off. Bulb out, new HID bulb into the holder. Wire up and test
Find places for the boxes. ballast only has short leads between that and the relay so decided to fit the ballast to the frame with the supplied Dual lock. relay fits neat into the underside of the headstock area. used double sided tape. This means the Transformer has to sit out behind the headlamp bowl, this is not a problem for the unit as it is solid state unit encased in resin.The problem came in re-fitting the lens unit, it was a fullbowl with another H4 connector in there plus the additional length of the bulb
Solution ... disconnect the H4 terminal block that fits onto the spades of the bulb, and disconnect the HID's H4 connector( so now thats 2 bits of bulky plastic swopped for male/female spades and shrink tube.
still not a good fit!!
the problem is the length of the HID bulb unit, the cable exit is to the rear and has a convoluted tube protection fitted!! The tube was cut a little shorter and a modification with a file means that the cable exits to the side now
This is satisfactory and the lens fits but its still tighter than i'd like.
After speaking to a couple of other people that have fitted the same kit, it transpires that they cut the rear out of the lamp housing
I priced for a new chrome bowl....£120....$240
so thats a no go.
I think that the head light unit is a pretty standard 7" unit and should be easy to find a substitute. i will then cut the rear out of it and 'extend' it with some fibreglass and resin for piece of mind.
I'll try to get some pics loaded to photobucket asap
