Twempie wrote:Check your oil after your next ride to see if it looks good in the sight glass.
The oil may be topped up enough to be coming out of the filler cap. Look inside the cylinder, where the filler cap goes. You'll see a small rubber-ring gasket. Small dirt particles easily accumulates around this gasket and should be cleaned or replaced when the oil is changed. I use one of those hardware-store paint can openers to pop out this gasket for inspection and/or replacement.
I've noticed my bike's filler cap leaks from time to time, usually when the bike gets hot on a multi-day trip or after an oil change fill-up (I have a non-OEM filler cap with an allen keyhole). The leak eventually goes away, I guess after the oil gets to a level the bike likes.
Hope this helps.
Thanks for the suggestion, but I've checked the filler cap, and it really didn't appear to be the source. Also, this is a significant event, with oil coating the entire left side of the bike and NO oil showing in the sight glass -- and this is 130 miles after an oil change.
Here's some more info that I just typed up on another board, so apologies for redundancy:
First off, I have little to no practical mechanical knowledge, so apologies in advance if my questions are quite basic.
Here's the deal. Today I took my 2004 twin-spark R1150R out for the first time since November, when my ride consisted of taking the bike home, at night, in the rain, from a major service at my dealer (about a 60-mile ride). I haven't ridden it since, and it has been covered so I don't know if this problem may have occurred on that ride without me knowing it.
Took it out today for about a 70-mile ride, and got home to discover the entire left side of the bike (and my left shin) covered with oil. Poked and prodded a bit, and didn't see any obvious leaks (the fill cap was on securely with no excess oil around it; the tubes to the oil coolers looked secure. I was thinking perhaps the dealer had put a bad head gasket on.
I was beginning to wash the bike and had only given it a gentle spray with water (nozzle set on "mist") when on a whim I decided to pull the plastic spark plug cover off. Lo and behold, a nice amount of oil came dripping out. So I pulled the spark plug wire, and, yep, there's a good amount of oil all the way in the tube near the spark plug. And since I didn't have the hose on a strong enough stream to force oil and water back into there, I think that may be the source of the leak.
That brings me to a bunch of questions.
It appears the spark plug hadn't been torqued properly. Does this seem like a reasonable conclusion? But the bike ran fine -- wouldn't there have been some roughness or misfiring?
There's now water and oil in the valve cover tube leading to the sparkplug. Can I just put the spark plug wire back on, or is it bad to have water and oil inside the wire cap? Should I try to reseat the spark plug using the spark plug tool in the BMW tool kit (which is all I have)? If so, how much force should I apply, since I don't have a torque wrench that would fit properly?
The bike has been ridden a total of 130 miles since the major service. Does this look like something I can deal with myself (i.e. tighten down the spark plug and see if it happens again), or should the dealer look at it? If so, based on what I've told you, does this sound like something the dealer should cover?
TIA!
