Oil Change Mistake
ronhartless
Oil Change Mistake
Post by ronhartless »
I've changed the oil in my truck many times, so I know the basics, but this was my first time changing the oil in the R1200R. I drained the oil, put on the new filter...but didn't realize that the rubber seal on the old filter didn't come off with the old filter. I put the oil in, jumped on the bike, started it up...sounded ok at first, then knocking/clicking, then the low oil pressure light came on...i then realized the oil was coming out from around the filter.
I shut off the bike, let the oil drain, and then took the filter off...at which time I noticed the old rubber seal.
I put the filter back on, put more oil in, and it seems to run just fine, but I'm worried I may have damaged something.
your thoughts?...other than calling me an idiot...i already know that :)
snag
Donating Member #: 639
Re: Oil Change Mistake
Post by snag »
As long as you didn't run down to the QuickiMart before you discovered the mess you're probably fine. I usually have my face on the floor looking under the vehicle when I first start it after an oil change. I once backed out of the garage and left a nice 20' X 1' oil slick down the driveway from my Accord after an oil change. The hour it took me to clean up the mess gave me time to consider the flaws in my oil change routine. I once had the oil filter on a Fiat Spider pierced by road debris on the way to Safeway. My daughter noticed the 2' slick under the car when we came back from the store. Since then I always look under the vehicle before I get in.
Plea bargaining does have its advantages.
'08 12R
'79 CBX
'74 CB750
ronhartless
no, i was quick to notice it. the engine probably only ran for about 30 seconds, then i got the oil pressure light, then i shut off the engine.
i put some white paper under the bike for the night to see if anything drips down.
parkec
Triple Lifer
Post by parkec »
Sounds like to me another engine break-in theory :D
IBA #50026
parkec
Triple Lifer
Post by parkec »
Seriously,
any idea how much you lost? I'm going to guess that your ok even if you had to add back a quart or so - considering you did not take off racing, or harley engine reving.
btw I notice when my spyglass oil level gets low the engine gets louder, kind of like an auditory oil warning :shock:
IBA #50026
ronhartless
I'd guess that it lost about 2 quarts, then the rest after i turned it off.
kay bill c
Post by kay bill c »
"I'd guess that it lost about 2 quarts, then the [REST ]after i turned it off." I am not sure I understand the [REST] part. How many Qt's did it take to fill it back up? If it took all new oil to fill it back up that's quite a lot, enough to worry about.2 - 3 Qt's should be OK if you did shut it off right away,Been my experiance working on trucks that once that light's on damage is following real close.
ronhartless
It lost about 2 quarts, i shut off the engine, the oil was still leaking from the broken seal. I had to take the filter off to discover the broken seal, so at that point the remaining oil came out. I replaced the filter, and filled it back up with new oil.
What are the symptoms of damage that might have been caused?...what should I be looking/listening for?
kay bill c
2 Qt's low for a few second's should not have any ill affect's.If there was damage you would most likly hear it.Sounds that were not their before,I don't know how many miles you put on this bike but most likly you know what the engine sounded like before,if it sounds the same ride it.If new clanks,bangs,grinds are there better stop by your shop.
These boxer engines are darn near bullet proof. Ride it.
ronhartless
I've put about 4,000 miles on it since i bought it. The bike sounds great. Unfortunately our warm weather has passed, and it's snowing outside, and it's going to be a cold weekend...so it'll have to stay put for a few days.
It snowed here in Va last nite and this morning. Not much though. Stopped already and roads are nearly dry here in Staunton. Work got canceled today due to weather. I can't resist---going for a ride this afternoon.
8b
Post by 8b »
Hey, when you other east coasters ride in this COLD weather, is your temperature readout on computer flashing like mine? (indicating ice possibility).
Post by deilenberger »
8b wrote:Hey, when you other east coasters ride in this COLD weather, is your temperature readout on computer flashing like mine? (indicating ice possibility).
Yes. Traditional BMW - on the cars - it also beeps.
vodka
Post by vodka »
To Ron,just a follow up. All OK after the oil change mishap. ?????
Your bad choice,no one else to blame.
