famousperson wrote:Dale_K wrote:A Ducati I used to own had a clever air shield in the area just below the steering head. It was a pleated plastic item kind of like a Japanese fan. The pleats let it collapse and expand as the forks turned from side to side.
What baffles me is that these designers neither use a wind tunnel in designing these wind screens nor give them much, if any, of a test ride.
The guy in Florida who spammed the MOA forums claimed to use a wind-tunnel, but he seemed quite nutty in his own way.. (aka - unreasonable - French even.
) Dunno of anyone else besides BMW who claims to use a windtunnel. Supposedly - Parabellum does do test rides. Problem I suspect also has to do with the greatly varying rider sizes/positions you end up with. What works for one person may not work at all for another. Problem is - none of them really "work" for me..
Don, certainly among your contacts you should be able to convince somebody to go to the rational trouble to do that before releasing these beasts on us, the unsuspecting public! The above pleat gizmo is the sort of thing they might come up with in playing around with different configurations.
Wish I had that sort of influence. I have discussed this sorta thing with a few of the shield makers - and most are quite resistant to making any change in a design they currently have in production. I guess a change would be admitting the ones they sold already perhaps aren't really so good.
Do any of the people who are having or have had trouble with screens ever give feed-back to the manufacturers? Would the manufacturers care if they did?
The only manufacturer who really seems to care is CalSci (Mark Lawrence) - he has called me several times, we've had long email exchanges, he's sent me stuff to try. He actually seems to want to make the perfect shield. Problem is - we haven't figured out what perfect is, and he doesn't want to make "hardware" (mounting brackets) which limits things a bit. I will be playing around some more with the test shield of his I have sometime soon - playing with the angle of it - since both I, and someone else here have experienced improvement by tilting it back more toward the rider. Some people have had very good experience's with Mark's shield - me - not so much, but it's likely a dimension thing again (me being short/plump/low-seat/short-arms.)
Sigh.. wish I knew what the answer is..
