dust cover?
adairb
dust cover?
Post by adairb »
My 2002 R1150R has a black plastic cover at the top of each fork tube that need to be replaced. One came apart while I was riding and I put it in my jacket until I got home. I put it back on with some black tape but want to replace both since the other one is cracked and will also break soon. Can I remove the fork cap and then unscrew the fork top bolt and then push the fork down and replace this plastic cover? Does anyone have the part number for these black plastic covers? My Haynes manual ( never buy a Haynes manual!!!) doesn't even mention these covers, so unsure of proper name and part number.
Thanks for the help and advice,
Barton.
lionlady
Re: dust cover?
Post by lionlady »
You might want to re-title this thread. I thought you were asking about a MOTORCYCLE dust cover, not the seal for your fork tubes. An important difference.
Should help get you some responses.
P
ATGATT: Because it's better to walk away in disgust than ride away in an ambulance.
