I have just bought a 2001 r1150r 40,000 miles. I went for my first 300+ miles trip yesterday. I also have a Triumph Thunderbird 900 on which I toured Scotland and Europe this summer. I thought I would offer my opinion on the Beemer as a new owner.
I started the bike for the first time and was a bit alarmed at the way the bike rocked from side to side when revved. A quirke I thought, but to be expected once reasoned through. I was initially surprised at the seeming lack of torque in top gear in comparison to the Trump. But I soon got used to the need to change gear in order to overtake. The engine and drive is very smooth, again to be expected, due to the shaft drive. The first 50 or so miles I admit to being slightly disappointed. Then I started to discover where the beemer scores well above the Trump. The brakes, wow they are great. The handling knocks spots off the Trump. It feels so sure on the road and whilst leaning into corners, well, it just fills you with so much confidence.. I even like the switch gear. The bog standard seat is more comfortable than the expensive King & Queen seat on the Trump. By the end of the run I was truly converted to the way of the Beemer. It's a lovely smooth comfortable ride and somewhat strangely attracts much more comment than the 'beautiful' T-Bird.
I have just one question. The 'Choke' doesn't seem to alter the revs at all. There does seem to be pressure on the cable when you move the lever, but there is no evidence of effect. As a fuel injected bike it begs the question, Why is there a need for a choke at all.
I will end by saying I am now a very satisfied owner of what is an excellent bike.
Some comparative thoughts on ownership
Hoathlyboy
Re: Some comparative thoughts on ownership
The rocking motion is quite noticeable at idle when reved up as it would when you hace a ~ 4 inch piston moing in opposite directions., not noticeable when ridden. Top gear doesn't fare well below 3000 rpm as it is an overdrive fr high speed running.
The "choke" is really a hand accelerator and has two positions, the first one is half way and has a detent, the second one you have to pull to the top of the travel and hold there, otherwise it will drop to the #1position. Forgeting to push the "choke" down from the #1 position doesn't affect theoperation, nor damage the engine. With the engine hot and the "choke" in the #1 position you should see about 200 rpm above the 1100 rpm idle. In the #2 position you should see about 1600 rpm. Less rpm require the "choke" cable to be adjusted.
Welcome and enjoy your new mount.
Daryl.Stamp
Congratulations, I've had mine for 37 months & 37K miles and am quite fond of it.
I hadn't ridden in 15-20 years and back then it was a v-twin Yamaha & before that a vertical twin Yamaha. The rear end felt so squirmy once I stopped to check the rear wheel lugs and then talked to the service manager; he looked at me, smiled wryly and said "Most of us refer to that as responsiveness, part of riding a Boxer.' I've become very fond of that 'responsiveness'.
It's easy to work on, easy to ride & will overtake most things on 4 wheels easily, and many on two.
Regards,
DLS
Regards,
DLS
- iowabeakster
Just to expand about what Boxermania said...
This big twin does is much happier turning more RPM's. I was suprised when I first started riding the bike. I was expecting more Harley type, ultra low RPM torque. Once I realized that wasn't the case, I find the motor plenty strong. Let the motor spin, and I am sure you'll find it a pure joy.
I now find myself mostly riding in 5th gear on my local county roads (55 MPH limits). Too many warnings (4 last year, 2 this year) from the friendly local law officers... they've yet to issue an award. They check my record...and don't want to be the one that puts a blemish on it. 6th gear is only for the interstates now.
Congrats...enjoy it...welcome...and there are still huge improvements to be made with an aftermarket seats and suspensions.
Hoathlyboy,
If you are not getting any RPM change from lifting the fast idle lever (Choke), you need a throttle cable and fast idle cable free play adjustments. Both of them are too large. This can happen with normal wear, misadjustment and a novice "on throttle" TB synch. Your cold starts will not improve until those adjustments are made. BTW, the "choke" is only a throttle stop advancing mechanism. It makes NO changes to the fuel mixture. Use it anytime and as long as you need it.
About the unexpected torque reaction when you gas it in neutral, it is the counter torque generated by the engine accelerating the very heavy flywheel mass that causes it, not the big pistons. The piston masses cancel each other out and their fast motion dynamic gyroscopic forces actually slightly dampen that engine tilting torque reaction.
My thoughts on ownership which you will never see mentioned is that
Don't go around corners in a high gear thinking you are in a low gear...
Outcome... engine stalls and the your ability to stay on the bike will be tested
due to the unusual design characteristics giving gyroscopic precession forces
you wont expect.
you wont expect.
