Water not draining?
Water not draining?
Ive recently noticed that when I wash my bike, water gathers around the inside of the fuel filler cap and does not drain away. I had a look and can see that there is a drain that is meant to drain the water away to avoid water going into the fuel tank. I washed my bike yesterday and noticed that there was still quite a bit of water around the filler cap this morning when I filled the bike up and I had to dry it up with some paper towel.
Does anyone know how to check these drain pipes and/or how to unblock them?
Thanks.
Thanks.
- azimuth551
Re: Water not draining?
I know what you mean, I just use my air compressor and blow the water out of these areas including around the engine cooling vents and oil cooler. Other than that, it will eventually evaporate and I doubt if water will get in the tank becasue of the seal on the gas cap. I keep this area clean with a rag and some LPS spray to keep the seal good.
Brent
R1200R
Brent
R1200R
You could try a can of compressed air used for cleaning PCs. Not too much air pressure.
Leaf Blower here.
Lots of volume at a low pressure. After a wash if the bike is going into the garage and not for a ride, I put an oscillating fan in front of the bike for an hour or so just to get air circulating into all the nooks and crannies to get the water out.
- NakedRider
I VERY rarely hose mine down for this reason. I wipe it down with just a wet rag after each long ride and that seems to keep all the dirt at bay.
About the only time I use a hose is if I've been out in the rain or a real muddy road.
Thanks for the heads up about the gas cap, however. I'll be sure to keep that in mind.
BMW R1200R - White
What is this "Washing " you speak of?
- Mollygrubber
LOL I feel you Celticus. Mine now has 8000km and I have washed it twice. Still looks amazingly good! Perhaps it's the fact that I get pissing down rain every couple of days during my commute.
I do, however, feel guilty about it. So when that feeling strikes, I come on here and look at all your gorgeous clean bikes!
2010 F800GS
Member #741
2010 F800GS
Member #741
- LumpyCam
At first i was alarmed by this too - "how and why would BMW let the water collect here? So close to our precious fuel source!?" Now i just let it slide. The rubber grommet to keep out the wet is on the inside ring, the outer channel is just to collect and divert moisture. More simply: It's supposed to get wet.
Kieran R1200R
First I'd like to say Hi Naked. We have both come from the Pellican board and bought R12R's about the same time.
I too am experiancing this problem. I get the air compressor on it after washing but I have to say that it takes alot to get it all out.
I haven't had a look but I will to see if it is a design fault or that the drain plug is blocked.
I suppose we have to keep an eye on it!
If the design is like the R1150 design - the drain hole connects to some metal tubing that is wrapped around the filler neck in a spiral - soldered in place. It then goes to a hose that connects to the tank feedthrough. My 1150 one plugged up solid enough that I had to use some wire and then weed-wacker-cord to clear it out. PITA.
Mine has become reluctant to drain once - I used a fine tip air-gun on my compressor at about 100PSI - shot right into the top hole. It took a bit - but it eventually cleared.
One thing to check - look for spider webs plugging up the hose at the bottom. There are some types of spiders that like to make egg-sacks in open hoses like that.
I have to wash mine at least once a week to keep the rust at bay. One of the biggest problems about living on the beach. The bike is just over 6 months old and some tiny rust spots have already started to appear on the tank.......great paint job BMW!! <note sarcasm>
I have never noticed any water collecting or staying for long though in the fuel cap....can't say for sure though since I've never really looked it. Just haven't noticed it.
09 Alpine White R1200R: Touring windshield, BMW panniers, Sargent Low seat, Throttlemeister.
Matt G.
Matt G.
