r1150r fuel filter
n9owk66
r1150r fuel filter
Post by n9owk66 »
has any body had any problem puting fuel filer out side of tank
Sunbeemer
Donating Member #: 593
Re: r1150r fuel filter
Post by Sunbeemer »
YES! You have to hold your mouth just right... :lol:
It will come out, really! Just work slowly, don't force anything (too much) and be sure all the pieces go back in the way they were!
I cant remember the sequence exactly, but it's something like...lift the lower edge of the plate out first, rotate it CW a little to get some hoses out, lift the top edge out then rotate it CCW ~90 deg to get the filter and pump assembly (including the sock) out, and voila! If that doesn't work, try rotating and tilting it the other way... and think like a German engineer!
You may be able to reuse the small hose clamps for the vent lines if you are careful prying them open, and be sure they snap close again, but the crimp clamps for the filter should be replaced with FI style hose clamps (available at Autozone).
Luck
ADIOS!
n9owk66
Post by n9owk66 »
will forget the external fuel filter on r1150r just got done its not a bad job just dont forget to get the fuel lines all the way together are u will hear the fuel pump making a bad noise
