Lights and fuses and switches
Hi, folks,
Considering pulling the trigger and getting a set of running / aux lights, finally, along with the case guards.
I noticed the Denali LED lights from Twisted Throttle (http://www.twistedthrottle.com/trade/pr ... /5224/594/; review at http://www.webbikeworld.com/lights/denali-led-lights/).
For those of you with a Centech fuse panel ... where did you mount it? There doesn't seem (to me) to be that much space under the seat.... Pictures would be helpful and most welcome. Any issues with installation or operation?
Thoughts on the AP1 vs. the AP2? How about using the automatic relay modules, the AP-130 or 170 depending on the panel?
Any problems with aftermarket seats e.g. Corbin?
Thanks much,
- Lewellen
Thanks much,
- Lewellen
Re: Lights and fuses and switches
No opinion on options since mine was the simple one..
Thanks, Don!
Did you mount the box right to the fender, or...?
Best,
- Lewellen
Best,
- Lewellen
Here is my install.....different location.... viewtopic.php?f=20&t=15597&p=138244&hil ... ll#p138244
alex
alex
Alex G. - San Francisco Bay Area - Member # 642
08 R1200R
07 GSX R600 - Totalled by EX SO
08 R1200R
Re fuse block - I mounted the Eastern Beaver PC-8 fuse block in the back area with a custom power loom from Jim too. Plenty of room for it. I like having both full-time and triggered circuits such as the PC-8 and the AP-2 have. Here is the installation:
Cy Young/VT (now NH)
13 R1200R (BLUE - the latest PSYCLE)
Right to the fender - 4 small screws/nuts. Piece'a cake..lewellen wrote:Thanks, Don!
Best,
- Lewellen
Don , That is a good looking fuse holder. I used a large fuse holder from a young person's thumper car stereo set up. It is larger than yours. I would like a smaller one ( never thought I'd hear myself saying that ). On occasion I make changes to the Centech's set up to make it more sanitary.
I looked at larger ones - but figured the chances of me drawing more then 30A from the fuse panel at one time are slim to none.. even my auxiliary lights are less then 10A. My heated seat is 3A, my heated gear around 6A or so.. Totalled it up and it was less then 20A, 30% fudge factor - 30A should work fine. Haven't had it blow yet.celticus wrote:Don , That is a good looking fuse holder. I used a large fuse holder from a young person's thumper car stereo set up. It is larger than yours. I would like a smaller one ( never thought I'd hear myself saying that ). On occasion I make changes to the Centech's set up to make it more sanitary.
I also have been known to disconnect and reroute wires to make things tidy - square off the corners so to speak. Obsessive compulsive disorder can display itself in lots of ways I guess.
I know you asked about the Centech but I went with the Blue Sea 5025 when I hooked up driving lights (Hella FF50s mounted on the crash bars), partly out of cheapness and partly because I wanted the fuses covered. It seems huge compared to the Centech and Eastern Beaver, but the nice thing is that once you get 10 or 12 wires hooked to it you don't have to worry about it going anyplace. The two relays for the driving lights (separate for high and low beams) are down along the right side panel (top of picture). The relay you can see is for the whole fuse panel.lewellen wrote:For those of you with a Centech fuse panel ... where did you mount it? There doesn't seem (to me) to be that much space under the seat.... Pictures would be helpful and most welcome. Any issues with installation or operation?
2007 R1200R, Memphis Shades Alley Cat, Sargent seat, Givi PLX cases
1981 KZ1100A1
1981 KZ1100A1
Looked at the BlueSea (appeal is marine use stuff is usually pretty good around wetness..) - but the size was just a killer for me. If I had it to do over - I'd consider one of the other moto specific ones with a relay switched key-power circuit and the always-on circuit. Might be handy for a few things.. but so far the simple Centech (which I owned) has done fine for me.
