Valve stem hole size
motojoe
Post by motojoe »
I did a search on this topic and read lots of great stuff on metal valve stems written here. However I only came upon one person who said he thought the hole size for the R1150R was 11.3 mm. Would someone confirm this as the correct size for a replacement valve stem. I am interested in just putting new rubber stems in and would also appreciate any good sources for these. Thank You
FloridaBeakster
Re: Valve stem hole size
Post by FloridaBeakster »
My package is labeled 0.453 inches, which works out to 11.5mm, which I guess is close enough to 11.3mm. It's the smaller of the two sizes available at NAPA. I also use the shorter ones (7/8 inch), as it can be a might difficult to get an air chuck on anything much longer.
-Mike
'02 R1150R
'88 R100RS
