R1100RT-P coils keep failing or burning out - please help!
TheBoxer
Post by TheBoxer »
Hi guys,
First, hello! I believe I had an account on r1150r.org sometime ago, but it appears to have gotten deleted (?). Anyway, I love this website and am hoping someone can help me with the problem I am facing. I would also like to note that I am cross-posting this same message on other forums...
I recently moved but have not been able to move my r1100rt-p because it won't start. I need to get it running soon because the place I was renting from is being foreclosed upon!
Anyway, here are the symptoms...
I tried starting it one day, after about a minute of normal idling, the idle became erratic (surging, etc.) I gave it some gas and it shutdown. After several starting attempts, I checked for spark -- there was none. I then bench tested the coil and found no resistance between either the primary or secondary.
I ordered a coil off ebay (I know, but I'm poor -- probably too poor to own a bimmer) it did not come in the metal case w/the large ground strap as the original had, but it was from a running r1100rt. I plugged it and got spark -- hooray!
I started the bike and it idled for a minute, then died. I checked for spark -- there was none. Then I bench tested the replacement coil -- again there was no resistance on the primary or secondary.
I have another coil sitting in a box on my table, but am apprehensive to plug it in; I was actually a little nervous this would happen with the first replacement coil. I searched this forum, google and a few others forums and have not found anyone whom has experienced this exact problem before. From what I have read the hall sensor is common culprit in ignition problems, but I was hoping to get some advice before I delve into that. I really just want to get it moved and don't have a lot of money to spend getting it going.
Any help would be greatly appreciated!
Zach
boxermoose
Re: R1100RT-P coils keep failing or burning out - please hel
Post by boxermoose »
how to check the hall effect sensor
http://advwisdom.hogranch.com/Wisdom/oi ... ensors.pdf
TANSTAAFL
