It's D.U.M.B.O. Time!
Beemeridian
Donating Member #: 477
Post by Beemeridian »
22
2015 Honda PCX150
n9owk66
Re: It's D.U.M.B.O. Time!
Post by n9owk66 »
goodone thanks
MIXR
Post by MIXR »
This is a plug I check often, particularly after an oil change, or change of oil type. Some oils 'fume' a lot more than others, and this is exhibited in the airbox by a slowly growing pool of oil. Even a long, fast, hot ride can pump excess oil (oil fumes) into the airbox, so any big run (high rpm, warm conditions) requires a two-second check of the airbox when you get home. Overfilling can also dump the excess here, if it doesn't leak out somewhere else first or burn off! Oil fumes on the air filter won't hurt anything, but the filter will get dirtier faster.
Also note that the R intake tube is low on the left, and collects a lot of water if ridden hard in very wet conditions, or when spashing through floodways. Note that the big jugs on the R are not designed to allow the bike to negotiate deep floodways. Even if the water is only up to the cylinders (well-below the air intake), the bow wave created flows up and over the cylinder and straight down the intake ram tube! And if you ever drown your bike in a floodway that's a bit too deep, this is where you drain the airbox before you pump out the cylinders. I know this well. I've done it.
Beemeridian is correct - This plug is often overlooked, and shouldn't be.
gregor
Post by gregor »
Have checked mine a few times and also after my recent, messy, oilchange. Never had even a smidgeon of oil in there. I feel deprived.
Buckster
Donating Member #: 543
Post by Buckster »
Wow...I never knew that was there! I always noticed a little oil in the airbox during services and simply wiped it out really well. Thanks for the info!
Buckster '03R
#543
Beemeridian
22
2015 Honda PCX150
Xdot
Post by Xdot »
I use it to lube my shifter balls. Makes everything slick, smooth, and highly sensitive to touch.
2017 Husqvarna 701
2007 Husqvarna TE250
2004 BMW Rockster
garr2
Triple Lifer
Donating Member #: 781
Post by garr2 »
Of course in Australia it's not possible to simply drain the air box of oil. I have to remove the air filter box and then turn it upside down before the oil will flow out the drain hole. You people in the northern hemisphere don't know how easy you've got it!
Beemeridian
22
2015 Honda PCX150
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
Thanks. I am a DUMBO. I've had this bike 9 years and I did not know about this.
:oops:
2002 Atlanta Blue
Lifetime Member #74
