After no problems with my 2007R I found this on my whiz bang 2011R, after the first few hundred km-
Both forks had similar signs of leakage.
This was readily acknowledged by the dealer as a fault and repaired under warranty at about 3,000 km but 500 km later it's back!
Could I ask all you 2011 buyers to check your forks to see if it is just mine or a wider issue (assuming you have not lovingly polished it every day...) On one of my photos it almost looks like the surface of the fork is scratched.
When the seals were replaced, I expressed my scepticism to the mechanic, 'surely 2 seals can't both be faulty' He did not disagree but said we had to tackle this one step at a time starting with the most obvious likely cause.
Not impressed...
