Bought one of these and it works!
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
Bought one and used it and it works! Fits through the rubber valve cover grommet/gasket nicely. I had been using a deep-well socket I turned down, but it wsn't as deep as this one so it wasn't long enough to reach the plug without an extension, which would often pop out of the socket and then I had to fish the socket out with needle nose pliers, so this is an improvement.
My bike never had a tool kit, so I've never had the correct spark plug socket.
If you don't either, this will work!
They're on sale at Harbor Freight:
http://www.harborfreight.com/extended-r ... rance_1030
ADIOS!
zbodan
Re: Bought one of these and it works!
Post by zbodan »
Will it fit into the housing of the secondary plugs? :?:
Sunbeemer
Post by Sunbeemer »
Can't say since I don't have them. This socket will fit in the well at the top (outer end) of the cylinder head valve cover to extract that plug.
ADIOS!
eduardobelmonte
Post by eduardobelmonte »
I bought one to.
It doesn't work for the secondary plugs.
It's too thick.
bimmerguy
Post by bimmerguy »
OEM Tool kits are available on fleabay if you ck weekly.
Got mine for $20. Never travel without em.
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
I bought one of these at Harbor Freight, on sale. I just got around to trying it last night. It did not fit in my 2002 -- it is too thick.
Bob
2002 Atlanta Blue
Lifetime Member #74
jm1515
Triple Lifer
Post by jm1515 »
Goto Advance Auto, Tractor Supply, Ace Hardware, HomeDepot etc and buy one of these if you can find....
http://www.alliedtools.com/products/13252
Works great on both plugs on my '04....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
mnnden
Post by mnnden »
rdsmith3 wrote:I bought one of these at Harbor Freight, on sale. I just got around to trying it last night. It did not fit in my 2002 -- it is too thick.
Thanks I tried to order one a while back but they were out of stock, I have tried several from different stores and none have worked, The unit that came with the bike will have to do (which it does) mnn
We all gave some,
Some gave all.
Anonymous
