Bike started running a bit rough, tickover slightly lumpy and it gets worse at 5k revs and larger throttle opening. So, having read some of the advice from members here, I did the following:
1. Removed both secondary plug leads (engine would start but ran v rough - definitely missing badly)
2. Removed RH Primary plug lead (Bike started and ran on LH pot ok)
3. Removed LH Primary plug lead and replaced RH (Bike would fire on RH pot but not actually start)
4. Tried running the bike more with secondary plug leads off, but it ran too badly to contemplate riding it.
Bike will still run pretty well (I rode it home 40 miles) but it's definitely missing and down on power - the wallop that should be there when you give it some gas at 5K revs has gone fishing.
On the basis of the above, I'm thinking that the RH stick coil is breaking down? Looking at the stick coild, the LH one is showing signs of corrosion, but from the above it seems that it's actually the one that looks fine that is on the way out (if I'm right of course).
So, before I had Motorworks or someone £70-odd for a new one..... do you clever lot out there think I've made the right diagnosis?
I saw the previous post on the same subject, and was intrigued by the Ford coil mod. However, I have no idea of part numbers or even if the coil that the clever guy in the states used is even available here, so keeping it stock is probably the way to go? BTW - these stick coils have to work in a very nasty environment for electrics - it must get VERY hot in that cyl head recess - is this why they age and break down so early in life? I've never had an issue with a coil going on any other bike I've owned in 30 years!
Oh -in case it's relevant..... The bike is an '04 Twin Spark and has just (today) rolled over 30k miles.
Thanks in advance of any sage-like advice and support!
Graham
