Winter Starting
zbodan
Winter Starting
Post by zbodan »
I'm riding to work on my bike this upcoming winter and I already am having trouble starting it at night.
The temperature lately has been 25-40 and my bike will turn over, but not catch.
My guess is the battery perhaps? How can I know if my battery needs to be replaced?
Also, I was suggested that changing my spark plugs to some cold-weather variant might help, if there are any.
Any thoughts?
Edit: Just for clarification, I do know it is the cold, because my bike started fine later when the next day when it was warmer.
I have thought of bringing a can of starting fluid, but having to open my airbox etc. every time I want it to start at night would be a pain; the air filter will filter out the spray, so I can't spray it right into the air intake, can I?
Sunbeemer
Donating Member #: 593
Re: Winter Starting
Post by Sunbeemer »
What weight oil is currently in your crankcase?
At those temps something starting with 10W (like 10W-30 or 10W-40) should be fine.
Re: Winter Starting
No starting fluid!! (Unless you really want to spend some money on engine repairs)
A good battery and 10/40 oil in the crankcase. I used to ride mine down to 10 degree temps (stupid on my part cause I did have a truck) but no more. Mine cranked a tad slow but it would light off after a few revolutions. How old is your battery? If it's much older than 3 yrs it might be getting a bit tired.
omg1010
Re: Winter Starting
Post by omg1010 »
zbodan, cold temp usually puts a strain on your battery and the symptoms you describe are signs of an aging battery. Suggest you get yourself the Odyssey PC680 as a replacement.
Brgds
Oliver
zbodan
Re: Winter Starting
Post by zbodan »
Thanks for the help!
My battery came when I bought the bike and it had 2009 written on it. So it's not too old, but it's getting there.
I'm running 20-50W oil, so I'm going to drop the weight.
Xdot
Re: Winter Starting
Post by Xdot »
My bike wouldn't start at all yesterday. Just chug, chug, chug, click, click, click. It's suddenly gotten quite cool here - high 20's at night - and I hadn't ridden since before Thanksgiving. I put it on a charger last night and it was nice and strong this morning.
Think about bike batteries. They are small so have less power available. These bikes have big engines with high-compression pistons. As large as some small cars. And electrochemical efficiency goes way down when temperatures drop. That's a lot to ask of a battery on a cold morning!
2017 Husqvarna 701
2007 Husqvarna TE250
2004 BMW Rockster
fpgirard
Re: Winter Starting
Post by fpgirard »
I had similar issues on a 3 year BMW battery. Got the Odyssey PC680 and have been happy with it so far. Its mounting height is a bit shorter but a small shim fixed that.
2003 R1150R
1995 K75 (sold)
R4R&R
Donating Member #: 293
Re: Winter Starting
Post by R4R&R »
So far my batteries have lasted about three years, then they are unreliable in the winter. I guess they get tired and to cold temps makes it obvious. If it's over two years old, I would replace it. A thinner oil in the winter can help too, but the primary issue is the battery.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
Biff's R
Donating Member #: 289
Re: Winter Starting
Post by Biff's R »
When i used Castrol Syntec 5W50 oil my bike started the easiest in the winter. I liked that oil the best, but I can get Mobil one for a lot less. The thinner oil will help on cold start up, but your battery needs a little love. Do you have a battery tender? I ran my OEM battery for 7 years but i kept it plugged in most of the time.
Jeff (lifer #289)
'17 F800GSA
