With all these windshield threads this should go over well! And as all of you know I've made windshields and turbulence my passion because I am going deaf from the noise!
Windshield turbulence is caused by a pressure and velocity differential between the air behind the windshield and the air hitting the windshield. As the air passes over the top of the windshield the 'vacuum' behind the windshield pulls it down. An oscillation gets set up which causes vortices of air coming off the lip along the boundary between the fast and slow moving air. These vortices detach and move along the air stream, contributing to turbulence. The low frequency booming you hear is these Von Karman vortices hitting you in the head. Here's a nice little video illustrating the effect: http://en.wikipedia.org/wiki/File:Karma ... linder.ogv
My research indicates there are three ways to lessen the effects of these Von Karman vortices as regards a motorcycle windscreen.
1) Reduce the pressure differential - most easily done by cutting a hole in the front of the windshield to let some air through
2) Increase the windshield rake to reduce the compression at the top of the windscreen.
3) Move the head of the rider closer to the edge of the windscreen. (You can see in the video that the turbulence increases as you move farther from the edge.)
So, last night I performed the first step - cutting a hole in the front of my windscreen. And you know what? It made a difference. These are the steps I went through
1) Mark the size and shape of the vent on the windshield. I covered the area with masking tape so I could draw on it and to protect the plastic.
2) You have to careful cutting acrylic. If the bit or saw gets hot it will start melting instead of cutting. It is also possible to shatter or crack the material so you need to be careful. You also don't want square edges as they cause stress in the material. I chose to drill large holes at the curves using a Forstner bit as shown. It was pretty easy though the bit did heat up. I found it worked best if I used pretty good pressure but a very slow bit speed. It sort of shaved the hole but was a bit tricky as the bit tended to stick in the hole. For drilling the holes I laid the windshield front side down on a towel with some newspaper between to drill in to.
3) Next I drew lines from the curved vertices tangent to the holes.
4) Use a jigsaw with a coarse wood blade. Make sure the blade is nice and sharp so you don't crack the screen. This was not hard. The material cut easily. Of course the front of the windshield was facing up for this step.
5)This is the hole after I cut the vent out which I then cleaned up with a file and some coarse emory cloth.
6) Here's what it looked like on the bike:
All in all it was a pretty easy job. The hardest part was drilling the holes. Just go slow and make sure you have a sharp bit. For the speeds we go I don't really think it matter much what the shape of the hole is, just that it make sense.
Next is to add a diverter to direct the air up along the inside edge of the windshield and increase the rake. Increasing the rake should also move my head closer to the edge.
