Thanks Keppelj,
Sounds like something to try.
Any known side effects to the moly? Leaks or ???
Amount to use?? The 10% was the product solution itself, right?
Sticky Downshifting?
Re: Sticky Downshifting?
I've used the mix for a year now with no leaks, wicking, other problems. Checking my notes, I used GD-421 (75-90wt) additive in both the trans and final drives and the ratio was 4 oz GD to 28 oz gear oil for 32 ounces, 12.5%, which is their recommended mix. Here's the link:
http://guarddogmolylubricants.com/gd421.shtml
As a post script, I see there is a newish tread on this subject in the MOA forum in the Oilheads:
http://www.bmwmoa.org/forum/showthread.php?t=57700
Great info guys.
Got to try it.
Sounds like it fits my situation here.
Let you know if it helps.
Got to try it.
Just to update on prior comments I have made on my sticky downshifts. 4/3 and 3/2.
I took suggestion of using guard dog moly. Drained and refilled with proper blend of moly and BMW Synthetic 75/90 tranny oil.
Today was first day to put any miles on it. A few short runs prior as weather permitted. 110 miles today from sunny Portland.
I am impressed. All shifts were smoother with or without throttle blips on downshift. The worst thing I felt on noted downshifts was slightly notchy but absolutely no sticking as previously noted. I am convinced that with the characteristics of this tranny, this is as good as it gets. and that "ain't bad"!!!
Thanks for suggestions and comments.
