Oil change
Bruno
Oil change
Post by Bruno »
Age old question when can I put full synthetic oil in my engine R1150R 15000 kilometers
owldaddy
Re: Oil change
Post by owldaddy »
When it stops burning oil. Usually 12k to 20k miles. Speed up the process by riding it like you stole it.
MIXR
Re: Oil change
Post by MIXR »
Or never!
goomicoo
Re: Oil change
Post by goomicoo »
My GS had 100,000 miles on it when I sold it.
Nothing but mineral oil was ever used and it did not burn or leak a drop!
You're changing the oil every 3000 anyway.
Using synthetic is like putting high octane gas in a VW bug. What's the point?
Atlantic Blue
2002 R1150R
The bumble bee's gone
rich1kim
Re: Oil change
Post by rich1kim »
Stay away from the synthetics. Causes oil leaks everywhere...eventually...for our bikes. Regular dino oil at regular intervals is best for our bikes. You'll probably end up selling the bike before you see any return on your money using synthetic oil. Well, it may cost you more than the increase in cost of buying synthetics. If your rear main seal starts leaking its gonna cost you $800-$1800 depending if you do the fix or the dealer replaces the seal. Lets not even get into the possible damage that may be done to the clutch plates...
Just use regular dino oil at the recommended maintenance intervals.
Also I don't recommend seafoam in the engine oil without a good reason and you know what you are doing. May cause oil seepage in the seals....for our bikes.
Biff's R
Donating Member #: 289
Re: Oil change
Post by Biff's R »
I changed to Synthetic at 6k miles. I have 64k now on the bike. The Castrol 5-50 is the best especially for cold starts. Buy it at Walmart, and change it yourself, and save $.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
bmwdave52
Re: Oil change
Post by bmwdave52 »
I put in Amsoil 20W-50 at 12k. After riding it like I stole it. Many thanks to the late Pat Williams for that info.
"When life throws you a curve lean into it"
Proud member since 2001; #17(Life)
Re: Oil change
I've been running Castrol 20/50 dino since 2003. In the past two years I've noted virtually ZERO oil usage or seepage. Of course the fact that I've not ridden the bike since May of 2010 has no bearing.
I have been cautious to keep my antifreeze topped off however.
