Question about replacing Brake Hose
Bruce R
Post by Bruce R »
Hello all,
I am working on a newly purchased '96 R1100R with ABS. After replacing the front brake master cylinder with a new anodized OEM from Beemer Boneyard, I found a small leak in the brake hose that is attached to the newly installed front brake master cylinder.
I have the new OEM hose ready to install. Do you suggest that I mostly fill up this 12" plus hose with brake fluid before replacing the leaking brake hose?
thanks
Bruce
1996 R1100R Grey
1999 Ducati ST2 Red
Metro Providence, RI
miker1100r
Re: Question about replacing Brake Hose
Post by miker1100r »
Hi Bruce!
Not sure how you would do that; it sounds kind of messy and brake fluid is very bad to slop on painted surfaces, rubber, skin etc. You'll have to bleed the system anyway so I wouldn't bother trying to pre-fill a new brakeline before installing it.
Mike
Mike
1998 R1100R
Bruce R
Post by Bruce R »
Thanks. I kind of figured out that trying to fill the replacement hose wasnt a good idea. Got it done the old fashioned way and now the brakes are operational.
1996 R1100R Grey
1999 Ducati ST2 Red
