Posting pictures
All other motorcycle related topics go in here." However, DO NOT post ANY messages that are related to politics or religion in here. They will be erased. Thanks!
captaincable
Donating Member #: 1050
Posting pictures
Post by captaincable »
I am trying to post a picture from Photobucket. I can go to P.B and right click on pix then hit copy url and then go back to post insert url but cannot do the same w/ copy image. Could someone give me a couple of tips so I can post? Thanks in advance. Mike 7o6 4nine9 seven775
Donating Member #: 2
Re: Posting pictures
Like this:
Click on little "img" button and "paste" the URL that you 'copied' from Photobucket inside.
captaincable
That's the way I have tried it several times , was only able to paste a url link. works the same way on other forum as you described but not here?
Try opening the picture from Photobucket in a "New" window and copy that URL from the browser address window. Then paste it as usual.
sjbmw
Moderator
Donating Member #: 263
Post by sjbmw »
When you hover your mouse over the pic In Photobucket, there will be a "Share/Copy" popup:
Click the "Direct Link" box if you are adding your own IMG tags. (Wait for "copied" to appear in the link box)
Or you can click "IMG code" box and paste it directly into your board post. (Also, wait for "copied")
It will have a link that ends in "jpg" but has image tag on both ends.
