These are the adjustment compromises most suspension shops know, specifically, what NOT to change when "adjusting things", so new and different undesirables are not added on. This is why it is nearly impossible to do an optimal suspension adjustment remotely, using the internet. It has to be hands-on, with the tools, fluids, parts, helper(s) and time to do so. Once you understand the simple basic rules, it becomes easier to:
1-Ride the bike thru sharp curves, bumpy corners and squeeze hard on the front brakes, or letting go of the bars and staying on course while cornering.
2-Note responses/anomalies and make assessments.
3-Make the many suspension changes (or front-rear wheel alignment) needed from the "as received" setup
-and-
4-End up with the correct settings on the 1st or 2nd adjustment session.
There are also consequences to raising the fork tubes TOO high:
1--front fender or fork seals may hit the lower fork tree before the forks bottom out.
2--the side stand will hold the bike too far upright (not enough lean-over).
3--putting the bike on the centerstand will be much harder.
After installing the RaceTech Gold Valves in my 2009 F800ST, the stock 12mm tube height (the part sticking above the upper fork tree) needed to be increased to 15mm (obtained by the educated guess change-n-ride method) to alter the bike's willingness to corner with little or no handlebar counter-steer effort. I removed the left & right lower body panels to gain easier wrenching access to the lower tree pinch bolts with the hand ratchet and torque wrenches. The additional 2mm forktube raise is essentially the normal minimum/maximum tube height increase for reluctant handling that is just a little bit "off" from it's ideal setting. This varies from different make bikes, as we found out trying to get a Suzuki 1200 Bandit to corner easier (without being forced to). In that case we raised the tubes about 20mm with no apparent improvement at all, whereas half that distance usually results in a dramatic, even an excessive "improvement". The solution was in extending the rear shock's overall length with a mounting point spacer washer. That too will cause problems with the drive chain occasionally rubbing the top of the swingarm, a larger variation in chain tension as the suspension works AND the bike leaning over farther on the sidestand. Despite those negatives the owner decided he liked the improved handling much better.
When I change the worn out front tire to the new Z-8, I'll likely have to change the tube height setting again to dial it in. Oh well.
Definitions:
static rider sag = compression amount in mm with the rider in the normal riding position (feet on pegs, hands on the grips, in full riding gear)+ bike at the balance point. Measured by fork compression axial distance of the tube/slider connected to the front wheel -and- the vertical distance the rear axle moves, both from full their "off ground extension" dimension to the compression distance with the rider on board. We take 2 measurements, a push down and let go settling point AND a lift up and let go settling point, then average the 2 readings to eliminate friction induced error.
! important ! - - - Be sure that job 1 is that the F/R tire pressures are where they belong before doing anything.
* Retired permanently and financially from our shop Aug 2005. Click on "suspension" and then "directions" in top menu header for more surprising info.
