HID?
Bobmws
HID?
Post by Bobmws »
Is there room to use an HID in the roadster headlight shell?
It seems kind of shallow, and I don't know how much room is required for the Hi/low bulb mechanism.
Bob Weis
Astatula, FL
04 R1150R-For Sale, 04 K12RS- Hannigan Hack
http://www.earplugco.com
tiPirate
Re: HID?
Post by tiPirate »
I inquired at TRS recently on the same note (1100R and 1150R have the same headlight, I think). For a full retrofit, there's some modifications needed in the headlight bucket, an enlarging of the hole. This is for a proper shrouded projector bi-xenon setup. Friendly folks, to be sure and the price seems very reasonable.
[email protected]
Hi Matthew,
Thanks for your inquiry and for your patience waiting on a response. Because of heavier than normal e-mail volume lately- it's not always possible to reply right away while still offering our customers the personalized support we're known for.
For your R1100R, the easiest projector to install with the best output would be the Morimoto Mini Bi-Xenon D2S. This kit uses a standard D2S HID bulb available at your local luxury car dealer should you need an emergency replacement. It requires little trimming on your headlight for the projector install, however, we have install guides on our tech page to give some insight:
http://www.theretrofitsource.com/resources.php
http://www.theretrofitsource.com/produc ... cts_id=927
The Sportbike Stage III Kit includes:
1pc Morimoto Mini D2S Bi-Xenon Projector
1pc Morimoto 3Five D2S Ballast
1pc Morimoto 3Five D2S Bulbs
Shroud of your choice
H4 Cycle-Specific Relay Harness
and is priced at $150 complete
You have choices with this kit. Everyone loves choices!
Bulb choices: 4300k, 5000k, 6000k temperatures. 4300k looks like sunlight, 5000k looks like fluorescent lighting, and 6000k is slightly blue in color. 4300k is the brightest (per lumen count), and as you progress into more color you lose usable light. Morimoto bulbs offer approximately 90% of the quality of the Philips bulbs at less than half the cost. Philips bulbs come only in 35w and 4300k, maintain their color for a longer period of time, and are OEM bulbs for a lot of factory HID setups. A visual guide is attached
Shroud choice: I usually recommend what will fit with little to no extra trimming required, and something that also matches well with the shape profile of the reflector inside your headlight (i.e. is it fully circular, oval shaped, shallow or deep, etc?)
To give you a visual of what this setup looks like, here are some links for you to our customer-supplied gallery:
Mini D2S Output: http://www.hidplanet.com/forums/album.php?albumid=225
Sport Bike Retrofits: http://www.hidplanet.com/forums/album.php?albumid=146
Since this was a lot of information to digest - don't hesitate to ask if you have any other unanswered questions. You can simply reply to this email, or give us a call at 404-220-7940 and we'll be happy to help.. Otherwise, if you've already made up your mind - you can put in an order through our website, request PayPal invoice, or call us to order over the phone.
Thanks again Matthew!
Andrew @ TRS
For the record I have no affiliation with this company and have not purchased the kit.
tiPirate
Re: HID?
Post by tiPirate »
Another point that's given me some hesitation is that where it's a real projector and not just a bulb scattering light, there's a definite horizon cut-off when the lamp is illuminated. This could cause problems when leaned over as there will be a dark spot right where you're trying to look through a corner for your apex and exit.
Some people have worked around the problem by leaving some clearance between the base of the shroud and the headlight reflector so some light escapes and scatters, but it seems like a big compromise. At this point I'm looking more into a relay set from Eastern Beaver and a better bulb in a lower Kº.
Bobmws
Re: HID?
Post by Bobmws »
tiPirate wrote:Another point that's given me some hesitation is that where it's a real projector and not just a bulb scattering light, there's a definite horizon cut-off when the lamp is illuminated. This could cause problems when leaned over as there will be a dark spot right where you're trying to look through a corner for your apex and exit.
Yeah, that is my initial plan, but I wanted to check the options. Just wondering if anyone has actually done the HID.
The HID low beam in my K-bike is awesome, just wasn't sure about the mechanical solenoid for the dual bulb.
FWIW, I recently installed Osram 90+ nightbreakers from Powerbulbs in my Camry, and they are noticeably whiter and brighter than the OEM Sylvania's.
The Eastern Beaver stuff rocks!
Bob Weis
Astatula, FL
tiPirate
Re: HID?
Post by tiPirate »
Sounds like it could be a good solution without the compromises, then. Let me know if you go with the HID conversion either way, I love mods that are subtle and "trick". :D
Ol' Jeffers
Re: HID?
Post by Ol' Jeffers »
Osram 90+ Nightbreaker is what I use on both my car and my bike. Very nice light output
and good colour makes for less long term fatigue. :)
OJ........everybody's pal!!
Bobmws
Re: HID?
Post by Bobmws »
I've not yet had the headlight apart nor the tank off. Looking at the Eastern Beaver website I see a water proof relay harness recommended for the GS, and bikes with a small headlight shell. Anyone using this one, or is there room in the shell for the relays?
Bob Weis
Astatula, FL
gregor
Re: HID?
Post by gregor »
I also recommend the Osram bulb upgrade. A whiter light and plenty of spread and range for my night riding.
Same wattage as standard and no mods required.HID conversions can cause a lot of angst. Allegedly.
Ol' Jeffers
Re: HID?
H4 i.e. twin filament type HID lights have I understand some problems the foremost being a
noticeable delay when you switch from main to dip or vice versa.
They're illegal on a bike in the UK and most of Europe and cars must be fitted with automatic
beam leveling devices.
omg1010
Re: HID?
Post by omg1010 »
I have had a HID replacement (dual-filament H4) in my R1100R. The bulb did not fit and I used this
to create the necessary space on the back of the headlamp (metal). It then always worked perfectly for years on my bike. No delays between lo and hi beam. But it was a quality kit ...
I would always recommend the change (even if it was illegal back here in Germany).
Brgds
Oliver
Airman
Re: HID?
Post by Airman »
omg1010 wrote:I have had a HID replacement (dual-filament H4) in my R1100R. The bulb did not fit and I used this
Brgds
Oliver
I remember you giving me that advice when my DDM H4 HID wouldn't fit. I couldn't do it and sent the light back, so I am still in the dark. Why is that kit so expensive? Is it because it's a projector lamp rather than just a simple bulb conversion?
omg1010
Re: HID?
Post by omg1010 »
I don't know what you mean by "expensive". I had bought this kit from UK (http://www.ebay.de/itm/BMW-Boxer-Twin-X ... 27b6f0c448) and I felt it was not "expensive".
Brgds
Oliver
Airman
Re: HID?
Post by Airman »
omg1010 wrote:I don't know what you mean by "expensive". I had bought this kit from UK (http://www.ebay.de/itm/BMW-Boxer-Twin-X ... 27b6f0c448) and I felt it was not "expensive".
Brgds
Oliver
The DDM kit was about $52 and it was pretty much the same as the kit you bought. Still, you did ok. If I had another headlight shell to beat on I might go ahead and do it. I really need the whole thing anyhow as the reflector has a broken mounting ear. EBay sells some units out of Germany, but I can't tell if the application is correct.
omg1010
Re: HID?
Post by omg1010 »
What do you mean by "if the application is correct"? You have a H4 headlight and the depth of the HID does not fit in the shell. Hence hammer the (metal shell) with the round hammer (pros do that on a beanie bag or leather cushion) to create additional depth. Worked fine for me.
Brgds
Oliver
