fuel gauge or lack there of?
just bought an r1150r 2002 and i am in love. told the wife i have a new mistress. anyway just curious what you guys think of the lack of having a fuel gauge. i know the light comes on at 5 liters but still. any thoughts on how this comes into play on long rides.
lguardiola
Re: fuel gauge or lack there of?
well I have only had my 04 R1150R for about a month...I ready in the manual that when the light turns on, theres still a bit over a gallon left, and this bike gives somewhere around 45mpg (give or take)...so I guess this should give you a reference on how much longer you can go...but I haven't any long ride (yet), so I'd also be interested in know how this would come into play on a 400 mile ride....
milehighboater
My 04 r is my daily driver and the light turns on around 190-200mi and try to fill up within 20 miles or so. I haven't pushed it till it ran out though. I think I have read the tank is good for around 235 miles at 75mph.
I've had my R for about a month, haven't ridden as much as I like due to some tendon problems and a walking boot. Like any bike I've purchased, I'll wait until the tank is low and strap a 1 gallon gas can on the rack. Note when the low fuel light comes on and run it dry.
After gathering some mpg data I will rely on the odometer as my main "gauge".
I'll be doing the same. Good infoBobmws wrote:I've had my R for about a month, haven't ridden as much as I like due to some tendon problems and a walking boot. Like any bike I've purchased, I'll wait until the tank is low and strap a 1 gallon gas can on the rack. Note when the low fuel light comes on and run it dry.
I have used the trip odometer for the 70k miles and 8 years of ownership for my 04. I can go about 40 miles safely on the low fuel light.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
'17 F800GSA
'04 R1150R
Like Jeff said. I reset the trip set each fillup and that is my gas gauge. My light comes on sooner than some (I found this out riding with someone else on the same bike) but mine comes on about 150 or 160 with my normal mountain riding. Around 185 or 190 on interstate runs.
Did have it sputter and die on the interstate once while stretching it too much. Pulled over, leaned the bike carefully side to side to slosh gas trapped in the bottom of the tank to the fuel line and it started and made it to the next exit! Think that was about 210 miles.
Probably more reliable than a gauge!
Vann - Lifer No. 295
yeah that.Biff's R wrote:I have used the trip odometer for the 70k miles and 8 years of ownership for my 04. I can go about 40 miles safely on the low fuel light.
Also - if you do run out, and you're desperate, and strong enough..... There's a couple of miles of gas (I've not measured exactly) in the left side of the "saddle" tank. If you haven't done the syphon mod (which we used to discuss a few years ago on this forum), you can do the following.
Lay the bike down gently on the right cylinder head (rest it on your gloves / jacket / some other random piece of material to avoid scratches), then tip the bike further as far as it will go.
Then SLOWLY reverse the bike back and lift it back to it's wheels in your preferred method.
You'll then have transferred the contents of the left "saddle" of the tank into the right side and the fuel pick up can get to it.
I'd estimate that there's roughly a litre of fuel there. Has worked for me a couple of times when I pushed the tank-range (and was running late for work!!)
With combined city/road driving, my light goes on at 135-140mi on my 02 R1150R. I am running a 32/11 (2.9) FD. When I had the original 31/11 (2.8), I got 48 mpg on a road ride to San Diego and back. What bugs me, when I have 120 miles on the tank and park it on the side stand, the light will go on when I ride it off later. Sometimes it will go out, sometimes not. I feel like I am driving and old Sportster, where you have a 100 mile range. My frustration is the small tank and the light system.
02 R1150R Black
02 R1150R Black
I've pretty meticulous about checking mileage on every fill up and resetting the odometer. In city, I'm getting around 39-42; on highways, it's 45. This means that the light comes on 135 or so in the city and about 150-160 on the road. And like Biff's R, I can get about another 40 miles.
I did run out of gas once - about 100 yards from the gas station and did the walk of shame.
2003 R1150R
1995 K75 (sold)
1995 K75 (sold)
- Dr. Strangelove
- Double Lifer
That light illuminates at different mileages depending on your riding style. Lots of stop and go city and much sooner--say, 120-140 ish, if steady speed hwy, maybe 170-190.
It will alert you that it's about to come on though, if it lights when on the sidestand. Also, each bike is slightly different, though each seems to be consistent.
In nearly 100k miles on my Stella! that light was always a good indicator, and like Jeff, I figured I had 40-42 miles left. I was only wrong about that once when I only had about 37. Fortunately, I was on a trip and had extra gas with me, so it was only a lesson learned and no great hassle.
Tell you this...peruse the r1200r forum and see what the new fuel strip adds to reliability; next to nothing. And the low fuel light is tied to the strip, ugh. The 1150s have a float gauge and it works well. The 1150 was the first vehicle I had without a fuel gauge, but watching for the yellow light was so reliable that even if I forgot to reset the odometer, it was no major headache. That said, I almost always reset the odometer, just to keep an eye on the mileage I was getting by seeing when the yellow light went on.
Enjoy.
BTW the mileage figures quoted by milehighboater, in my experience, are way optimistic for my 1150. I've never gotten more than 222, or 225 on a tank, once only, and I was REALLY sweating it, but did not run out. Can't remember what she took, but I was on fumes. Milehigh B, that's great you get that, but I think you take the record for mileage.
Enjoy.
'09 Schwarze Blanche DuBois
Ty everyone for the great input. I intend to apply a few of these methods.what is the fuel strip i must ask.
- Dr. Strangelove
- Double Lifer
The fuel strip replaces the float level for gasoline volume. It is essentially a long computer chip that reads the level of fuel, as I understand it.
Reasons for failure are unclear but have been postulated to be:
Ethanol in gas
Overfilling the tank
Poor design by BMW.
All above have pros and cons. No clear answer.
Interestingly, on the new RTs and GSs the float returns while the RRs still have the (failing) strips.
It's way more common than the 1150s clutch splines and FD issues
It's more of a nuisance than anything else but does detract from the pleasure of carefree? riding.
Ethanol in gas
Poor design by BMW.
milehighboater
Doc: Most of my driving is highway. If I was in the city I'm sure my milage would be getting much lower. But remember, just because we have 1130ccs doesn't mean we have to drive it like we do.
- Dr. Strangelove
- Double Lifer
Milehigh, got me there. Busted!
I do ride it like it is 1138cc
Best mileage I ever achieved was 56 mpg and that was coming out of the Big Horn range so miles and miles of downhill. If you get that consistently, that's terrific, and I think better than most get.
stay safe
stay safe
Being used to my late R100CS, I didn't had a fuel meter at all, just a stutter to tell you to go on reserve. Besides that the odometer gave an indication of when to refuel.
Still I'm diappointed in how far I can get until reserve and I'm fooking for a way to carry more petrol.
I thought about a GSA tank, but that means almost a rebuild of the bike and is much to costly.
previous R100CS
previous R100CS
- Dr. Strangelove
- Double Lifer
the light replaces the stutter; use of the odometer is the same.
how much fuel do you want to carry?
When the light goes on you're usually good for at least another 35+ miles, depending
milehighboater wrote:Doc: Most of my driving is highway. If I was in the city I'm sure my milage would be getting much lower. But remember, just because we have 1130ccs doesn't mean we have to drive it like we do.
I hope you do occasionally clear it out a bit.
R100CS wrote:Being used to my late R100CS, I didn't had a fuel meter at all, just a stutter to tell you to go on reserve. Besides that the odometer gave an indication of when to refuel.
Neck filler mod will give you around 2 more litres. (enough to get over 200 miles from a tank reliably).
Syphon mod will give you access to the left side of the saddle tank.
