Couple of well nuts missing...need a source to procure
Rider Rick
Donating Member #: 934
Post by Rider Rick »
These well nuts are the ones that help fasten the oil cooler body pieces to the tank area as well as the side body pieces when they fasten to the back of the tank. They are rubber covered and threaded in the middle. Also missing one of the rubber grommets that help hold the little tip on the side pieces to fit into the holes at the back of the tank.
BMW sold me several before they went out of business here, and when I went to use them they were too large.
Are these common items on other bikes besides BMWs? I'd never encountered them before.
2004 Red R1150R
kirby
Donating Member #: 3
Re: Couple of well nuts missing...need a source to procure
Post by kirby »
Good hardware stores sell these type of fastners, not had to find!
good luck,
mike
mike Mojave CA
'04 ROCKSTER
Rider Rick
HA! :shock:
Thanks, Kirby, I never would have guessed, lol. I immediately called my local Ace and they have different sizes so I am on my way over, lol.
2004 Red R1150R
Airman
Post by Airman »
Rider Rick wrote:HA! :shock:
Right. I bought some at Home Depot. I think they were less than a dollar apiece.
Rider Rick
:mrgreen: Tickled green, lol. I swapped out the screws and well nuts, as well as new grommets for everywhere, now to get them all replaced, thanks again. They are also black, so only difference is I also will use a washer, but my old screws are kind of gnarlied up, new threads are a good thing.
2004 Red R1150R
kirby
Post by kirby »
Rider Rick wrote::mrgreen: Tickled green, lol. I swapped out the screws and well nuts, as well as new grommets for everywhere, now to get them all replaced, thanks again. They are also black, so only difference is I also will use a washer, but my old screws are kind of gnarlied up, new threads are a good thing.
Hey, my pleasure!!
mike Mojave CA
'04 ROCKSTER
Rider Rick
:lol: I don't know why I feel like I rebuilt the motor or something. After I replaced all the well nuts on the bike and the rubber grommets that help hold the side pieces on, I stood there feeling like Clark Kent after saving Lois again. (laughing).
Now to get the metal valve stems installed...never-ending story, lol.
2004 Red R1150R
Biff's R
Donating Member #: 289
Post by Biff's R »
Good to hear you were successful.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
Rider Rick
Yea, things go on much more easily, although I STILL forget that the middle bolt goes on before the body piece over the oil coolers, lol.
Does anyone else hear a tapping noise like something knocking for a couple of minutes when first starting up the bike? It goes away, but I wonder if it is the camchain tensioner or whatever I read about? I will try to record it this evening when I crank it up. Doesn't do it after it is warm and I restart. I've read about this somewhere on here, will go looking.
2004 Red R1150R
There should be captured washer within the well nuts anyway. I'm not surprised they've disappeared over time though.
Rider Rick wrote:Yea, things go on much more easily, although I STILL forget that the middle bolt goes on before the body piece over the oil coolers, lol.
Probably the tensioner yes. The mod to put the replacement part in is pretty easy.
Rider Rick
Morning, I tried to record the startup with my phone but it sounded like a death metal song, lol. I think you are right, need to see what the fix entails. It doesn't last long, maybe 20 seconds, then goes away after I push down the high idle and rev it a couple time.
2004 Red R1150R
Bobmws
Post by Bobmws »
Rider Rick wrote:Morning, I tried to record the startup with my phone but it sounded like a death metal song, lol. I think you are right, need to see what the fix entails. It doesn't last long, maybe 20 seconds, then goes away after I push down the high idle and rev it a couple time.
Take the time to read the entire thread http://www.advrider.com/forums/showthre ... +tensioner, it appears to be fairly easy, may not need to remove the throttle body (read it all). I'll be doing mine soon.
Bob Weis
Astatula, FL
04 R1150R-For Sale, 04 K12RS- Hannigan Hack
http://www.earplugco.com
Rider Rick
Morning, I did just that, thanks for the link. I may leave it for now, it hasn't been making as much noise since I gave it that first shakedown ride, and I have some engine bars on, and I don't fancy removing that tank for a bit, lol. If it starts doing it more I will likely tackle it.
2004 Red R1150R
kirby
Post by kirby »
Rider Rick wrote:Morning, I did just that, thanks for the link. I may leave it for now, it hasn't been making as much noise since I gave it that first shakedown ride, and I have some engine bars on, and I don't fancy removing that tank for a bit, lol. If it starts doing it more I will likely tackle it.
Rider,
If you do change it out, it is easy to back the throttle body out of the way without messing anything up. Just
1. disconnect the injector electrical plug (do not have too but makes things easier) and pull the 2 bolts out of the injector and unplug it.(so fuel lines will not be in the way.
2. remove the bolts (2) holding the throttle body to the head.
3. loosen the clamp on the airbox side (rear one) of the intake hose/duct (very lose) not the front one!leave it alone.
4. carefully slide the throttle body back so the intake hose/duct inters the airbox (about 4 or so inches)
5. now you can get to the tensioner easy
This method has worked for me on several changes. It will not mess up the syn or the throttle cables. About 30 min job.
You SHOULD change it, not good on the chain and sprokets for it to be slaping. You do not want to go there!
cheers
mike Mojave CA
'04 ROCKSTER
Rider Rick
Well you made it sound pretty easy, so I may just do that, lol. I spent the day wiring in my Zumo and tpms system, plus reworking the mounts on my ADVMonster lights, so I think I'm ready to deliver it to a place that will install some metal valvse stems on it Monday. MotoGP week will be here before I know it. :shock:
I really need a taller shield, dangit. My shield now is about 21" though slanted back, but I'm still getting some buffeting on my helmet. I noticed at Cee Bailey I can order one a couple of inches higher, that would hopefully get the air off my helmet a bit. Man, my bonus is shrinking every time I get on the internet, lol.
2004 Red R1150R
