Is what you get when you neglect the cleaning out of a starter motor and try jump-starting the bike 3 times in as many hours.
Got the brakes fixed though!
Sadly I had a 90,000 miles without a cleanout starter and a weak battery. So I jumped the bike to get it running again on the old fuel in the tank, and took it out for a ride (obviously I had to jump it again after getting into my gear).
Bike was running well, bit vibey, but that was beginning to smooth out, probably mostly caused by the old fuel. Pulled over to get fuel (brimmed it with high octane to help clean out the injectors), and the damned thing wouldn't start again.
Managed to get a kindly motorist to help me, and while I'm leaning over the bike hitting the starter, and it's making recalcitrant whining noises and not starting, my nose starts twitching.
The smoke coming from behind the starter motor cover convinced me!
Said 'thank you' to the kindly motorist and whipped the cover off. Jump-peg and starter motor are too hot to touch (thankfully I have asbestos fingertips!), but I couldn't see any external signs of burning, so in some way's I'm hoping it's all just internal to the starter/solenoid unit, which will hopefully be an easy replace.
Has anyone else had an issue like this? What other possible damage have I done?
I tried bump-starting the bike as well - but only succeeded in locking up the rear wheel and dropping the bloody thing.
Mind you - it's so scratched anyway I couldn't see any new damage!
