Full size system cases on R1150R… is it really possible?
Endgame
Post by Endgame »
So I replaced the stock muffler on my 2004 R1150R with an 8” hot tip. I thought that would allow me to install full size system cases as several people have done as I thought I’d read in the forums.……
BUT….looking at the bike I noticed the passenger foot-peg plates have the plastic cap on the back that fits/supports the front side of the cases. On my R1150R the left side passenger foot-peg plate is bumped out about an inch or so to make room for the muffler.
My question: Will a full size bag (and which one) have a notch in the right place of the case to accept the ‘bumped out’ support cap on the left side of my R? Thanks!
Here's a pic of the plates with the end caps and 'bumped out' left side (on the right in the pic).
Other pics here: http://2004-r1150r.weebly.com
Now 2004 BMW R1150R-2013 Suzuki DR650
Before BMW R100/7-MotoGuzzi V7 850GT-Suzuki GS750-Honda CB500
sweatmark
Septuple Lifer
Donating Member #: 208
Re: Full size system cases on R1150R… is it really possible?
Post by sweatmark »
search.php?st=0&sk=t&sd=d&sr=posts&keyw ... +size+case
Answer: no.
But if you do some homework via the search results, then you will learn how to mount the full size left case.
You need to either fit a different (home-brew) bracket to the foot peg, or fit some locating lugs to the full-size pannier.
I went for the latter route with a couple of light metal bent plates bolted to the pannier in a suitable place.
the main weight of the pannier is taken by the pannier rails and the upper hooks - the lower support is mostly just to stop the thing swinging around. (it takes some weight, but not a huge percentage.)
(no pics at the moment).
P_Jensen
Donating Member #: 1130
Post by P_Jensen »
As Sweatmark said it is not a direct fit, it is easier to adapt the case to the bracket than to adapt the bracket to the full size case. A piece of C channel of suitable size bolted to case would be the easiest way to go.
P Jensen
14 R1200R
Montego Blue
NW VT USA
Endgame
Post by Endgame »
Thank you all! I searched the forums some more and indeed found examples of adapting the left system case to accept the ‘bumped-out’ bracket.
So just to make sure before I order my cases.
For my 2004 R1150R I should order (both) System Cases that are listed for the R1150RT. The right case will be a perfect fit and the left case I can adapt to accept the bracket? Correct?
sweatmark
Septuple Lifer
Post by sweatmark »
Endgame wrote: For my 2004 R1150R I should order (both) System Cases that are listed for the R1150RT. The right case will be a perfect fit and the left case I can adapt to accept the bracket? Correct?
Yes.
wncbmw
Post by wncbmw »
You have your answer about the bracket. You will love the extra capacity.
Vann - Lifer No. 295
Just don't try to lane split! :lol:
towerworker wrote:Just don't try to lane split! :lol:
I always thought that it would be harder - but the panniers only add about an inch (maybe 2) to the overall width. If the bars go through easily - you're ok. :)
(albeit the Rockster bars are a lot wider.... ;) )
wncbmw
Post by wncbmw »
The extra capacity comes from the inside. Where the exhaust was! No extra width over stock saddlebags. Although I do have some white paint on my pannier because I forgot about the extra width of saddlebags versus no saddlebags! :oops:
ron prior
Post by ron prior »
Endgame wrote:Thank you all! I searched the forums some more and indeed found examples of adapting the left system case to accept the ‘bumped-out’ bracket.
If you look around for an exhaust lowering kit, {Wudo} for example included the [foot] relocation bracket for the left bag. This is what I have on my "04", along with a Remus Y-pipe & muffler. Although not loving the sound...it all does work well together as far as fit.
Endgame
Post by Endgame »
Thanks all, will order RT cases today.
Yes definitely want the extra capacity. The full size case is 20% (6 liter) larger than the exhaust impaired version.
I'm pretty happy with the exhaust sound with the 8" tip and no muffler. It's a bit louder but no big deal, ride with earplugs anyway.
Here is a sound comparison on youtube:
With stock muffler:
https://www.youtube.com/watch?v=-H-OQYoKkTc
Stock muffler removed:
https://www.youtube.com/watch?v=F9waTcFgVeg
windy
Post by windy »
I also wanted a larger left (port) bag, and bought some BMW touring lids. They are about four inches wider than the standard lids. I also have the city lids,which are great for everyday use. You may be able to find them used for less money. :)
swamper
Post by swamper »
Try Beemer Boneyard. http://www.beemerboneyard.com/
IBA#7147
