After NEVER seeing even 40mpg, THe bike returned an almost 44mpg average on my weekend trip. and alot of it I was FLYING. so im happy now.
I think it was mixture of problems, But I REALLY believe the sticky rear brake was the major culprit.
SO if you are having LOW mpg. check sticky brakes. Plugged hoses, flush them, replace if needed, clean the slides etc. My "tell" was the BURNING hot disc after only riding 8 blocks.
after brakes are ok, do ALL the maintenance. valves, TB balance, reset motronic, new plugs...all that jazz. then. add some Techron at fuel stops.
the following thread, I will leave just as it is for future reference.
SEE BELOW for original problem.
I am displeased.
Iv'e been doing some keyboard researching...but I'm only getting more displeased the more I find, so Ill try a new post.
My bike has really never gotten the miles per gallon like i see reported, not close... Normally 34-36. I had attributed to riding style, and short commutes. But...just recently got a really good service. And babied it over two tanks. first tank. 31.6. 2nd tank, 32.4. And I had REALLY hoped it would improve. Valves, TB balance, and new plugs especially.)
So, I have some thoughts that I might have done something wrong, or overlooked something....
Ill go over my concerns.
-tb balance. it runs smooth. But I wonder, could the left side have too much slack...? The fast idle lever doesn't seem to affect idle like what Iv'e seen it should when researching. could this have an adverse affect on fuel mileage? Maybe not getting much air....therefore rich? Is there a base setting for throttle slack for left side? TB's are balanced though... New to the Beemer FI but it seems simple enough...
-canister: when I pulled the tank off this last time, the stinky gas/water/dirt mixture prompted me to yank the canister. Could I have mucked something up here? IE: capped wrong hose....maybe have a vacuum leak?
- air filter. Just thought of something....otally Forgot I failed to procure the correct air filter. I was sold the wrong one, having never seen it. lol So, just blew it out really good with air compressor.. Could that affect MPG THAT much?
-could there still be bad gas? what is the best way of draining? Maybe i didnt get it all out, after noticing the backed up drain hose....?
other things I haven't messed with, but thinking of: O2 sensor, cat code plug, Ill check my tire pressure again-they are new, wheels spin freely. Also, could it be the mix of cold weather riding, AND short commute? Both tanks. Daily commute of 22 miles round trip. 18 of which are straight line highway, 60-75mph. 2 stop signs. no stop/go
is there something more sinister afoot....
any suggestions?
I'm all ears(eyes) thanks folks!
EDIT: For reference, I am currently looking into a dragging rear brake as the cause of the poor economy.
see thread here.
viewtopic.php?f=2&t=34197
