after some testing, I have realized I don't believe it has anything to do with the motor or tuning. Im thinking it is my rear brake dragging. I have a 2002 1150r. with the servo ABS. Learned that after a couple of mistakes(and messes) the other day. I didn't realize the caliper was on a different circuit than the pedal.... So I'm still learning here, and need some help.
here's the symptoms.
-LOW MPG.
-fast wear of rear pads.
-If I don't even touch my pedal for 10 minute ride, I'm still finding the hot disc, and squeezed caliper.
SO it appears its tightening up on its own, and I just don't totally understand this.....
I did a flush and bleed last night of the caliper's circuit. I did not do the pedal circuit. And, It had tightened itself up and was still hot after the ride this morning. even after checking the caliper was plenty loose before leaving.
What should I do next? Keeping in mind, I don't want to dump ANY $ into it, only to have the ABS fail and have to RE-do it. And, on that note, I would just replace the lines NOW, but I'm not convinced that would solve it.
is it the lines(they all look pristine, and no crap came out....is it the caliper...or worse, the abs itself?
A little lost here. ANY help is appreciated! THANKS!
