L.E.D. Headlamp
ron prior
L.E.D. Headlamp
Post by ron prior »
Has anyone converted the 55/60 watt headlight bulb to an L.E.D. ? Gotta source ?
voipwizard
Re: L.E.D. Headlamp
Post by voipwizard »
I'm interested as well. Tried a couple of HID's hi/low, not enough room for the ones with the little device at the end.
2004 R1150R / 2009 R1200RT
ron prior
Re: L.E.D. Headlamp
Post by ron prior »
voipwizard wrote:I'm interested as well. Tried a couple of HID's hi/low, not enough room for the ones with the little device at the end.
I found this ............Replacement LED Headlights - xkglow.com‎
Adwww.xkglow.com/LEDHeadlights‎
And this ...........https://www.superbrightleds.com/cat/led ... sion-kits/
The first one has a replacement headlight assembly {7"} [for] motorcycles [can-bus] compatible but pricey .
The second one has an easy to navigate site, for cross-referencing all bulbs.
Give them a look , give us your opinion.....
Looks like you may have to 'google' xkglow direct ?......it didn't paste ?
Mr.Frequent
Re: L.E.D. Headlamp
Post by Mr.Frequent »
That's about 1.4X lumens over an H4. That would be great! The amperage reduction would be a benefit as well.
Bad part is that L.E.D. lights have an emitter rather than a filament. Most of these emitters aren't aligned to project in a proper pattern through a HID bike headlight lens , especially a glass lens that is faceted to spread the light in a useful way.
I'm not sure of ballast room on those items either,and have never seen one with a fan .A mechanical fan would mitigate the advantages of going LED , perhaps. Most LED solutions I've seen are expensive,but I'll keep looking . :)
carl1957
Re: L.E.D. Headlamp
Post by carl1957 »
I see that there would be the advantage of long life with an led headlight. However, modern H-4 headlights are far ahead of their ancestors regarding their brightness, dispersion. I have to wonder if we need them to be brighter? I have been nearly blinded by high-tech headlights of oncoming vehicles. When is enough, enough?
