Follow up, these QD connectors work flawlessly. Hardest part was pulling off the old connectors.One paper towel is all that is needed for the little dribble of fuel when pulling the tank. Which I had to do twice in succession due a new faulty Motobatt battery (returned and bought a Oddesey). ALWAYS check the voltage of a battery before install rather than just throw it on a charger to top it off.
Just saying....
Quick Disconnects (again)
Tundra Dweller
Re: Quick Disconnects (again)
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
2008 Suzuki Bandit 1250
2013 BMW GS 650 Sertao
1975 Norton 850
2002 BMW R1150R
What tools did you use to remove the stock BMW hose clamps?
Holland Ja, San Francisco
‘02 R1150R black
‘02 R1150R black
Tundra Dweller
Needle nose pliers, squeeze the crimp and pull them apart. Any rubber/metal/plastic connection, vacuum lines, hoses, spark plug boots need a back and forth twist to break the bond before pulling them apart.Hyja1 wrote:What tools did you use to remove the stock BMW hose clamps?
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
