When my light comes on, I have a gal 1/2 US left. This usually happens around 150 miles after I fill up. I once went 209 miles between fill ups but that was out of nessesity as I could not find an open station in the middle of nowhere at night. The last few miles were nerve wracking to say the least. It took 4.9 gallons to fill the tank which is a little too close for me.
Reserve on - 160 to 190 miles
Maximum mileage - 200 to 236 (new record by wardie)
You will never run the tank dry since some gas will always be trapped on the low portion of the tank opposite the fuwel pump pick up. If you actualy run dry, just tip the bike over to the right side to get some gas to come over and you'll run a couple more miles.
Best advice.....don't run dry, if you can help it, first, it's dangerous, second, it's embarrasing......
The furthest I have run is 187 miles, and the bike took 3.9 gal US, which is about 48 mpg.
Usually have about 175 miles on the trip, when the light comes on, and usually takes 3.5 gal or less, which is about 50 mpg.
I just turned 4300 miles tonight, so the bike isn't quite broken in yet. Lots of smiles, so far, though.
Hmmm, my low fuel light comes on when I hit about 140 miles. Of course, I'm not particularly easy on the throttle and my rock only has 1200 miles on it. Does mpg improve as the engine settles in?
I had only gone 190 miles, all city traffic work commute and one 50 mile flogging on my favorite road. That's just under 39mpg, the worst I've ever calculated. When I'm doing more highway running I've seen 52mpg.
shelion wrote:Does mpg improve as the engine settles in?
Not in my experience. My mileage is the same as the day I rode it home, and that was 14k miles ago.
I've never gotten 190 miles...even on interstate only trips. I must ride more squiddly than I realize!
"If you can't say anything nice, at least have the decency to be vague."
Well I finally found out the answer to my own question. I coasted into a station on Sunday and put 5.2 gallons in to fill it up.
So now I know.
Thanks for the feedback.
My mileage has been improving (up to 13k now) from the first fill up. I can get upwards of 48 if I'm not being too aggressive and 43 if I am. Avg now around 45.
My problem is that the reserve light seems to go on around 3.8 gallons or 175 miles, and I'm good for another 50. That's too soon in my opinion.
My bike's reserve light comes on around 3.75-3.8 gallon as well. Once I forgot my wallet and pushed the bike to over 200-miles to get home. I filled up 5.1-gallons. Personally that's too close for comfort for me.
I only get 130 - 135 miles before my warning light comes on. It usualy then takes about 14.5 - 15 litres to fill it. Always a bit paranoid about running on the reserver light. i only average about 35mpg. Admittedly I use all of the revs.
My low fuel light comes on with a considerable amount of fuel left in the tank. This is true especially when parked on the side stand. The light goes out after I drive the bike a short distance. Recently, the light came on and it took only 2.4 gallons to fill up. That is probably less than 1/2 of the tank capacity.
just get a small gas tank, strap it back on your BMW and ride out as far as you can with full tank till it runs out. Look at your mileage and memorized it. Then fill it up from your small gas tank. There, problem solve.
Typically, my best is 40 MPG. Reserve comes on around 135-140. Usually fill up around 160 and it takes a little more than 4 gallons. Been that way since I bought it (13000 miles ago). I ran out of gas once at 189 miles - sloshed the bike around and it started back up, rode 1/4 mile to a gas station and put almost 5 gallons in it. I don't think I ride it that hard, I commute on mostly highway, 80 mph (indicated) in sixth.
Well I finally answered my own question. Ran out and was able to coast into a station. Put 5.2 gallons in and got 240 miles on that tank full. So if you have a light that seems to come on prematurely like mine, and your bike is broken in (my range started out at 160 and now breaks 200 without a sweat after 12,000 miles) you should easily top 200 miles unless you are going for land speed records.
